Author Topic: split pipe with pics!!  (Read 1544 times)
Offline paul7278
  • boom boom problem solved!
« on: 10 April 2010, 17:37 »
Done a oil and filter change on mk 2.0 8v today and stumbled across a split pipe think its a breather? The car feels jerky when you lift off could this be causeing it?  :sad:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: split pipe with pics!!
« Reply #1 on: 10 April 2010, 17:47 »
It won't help matters but you'll probably find the jerkiness on lifting off from the accelerator is due to a manky throttle body and / or a worn engine mount.
Offline paul7278
« Reply #2 on: 10 April 2010, 17:49 »
thanks mate! are these genuine parts only?
Offline snifferdog
« Reply #3 on: 10 April 2010, 17:58 »
Throttle body just needs cleaning, its an easy job theres plenty of threads on here about it.
« Reply #4 on: 10 April 2010, 18:10 »
As above ^^^
Offline mattkh
« Reply #5 on: 10 April 2010, 18:53 »
Hi
Clean the throttle body.
While you are waiting for the hose from VW, wrap some wide sticky tape and test to see if this cures it.
Offline bmw156
« Reply #6 on: 10 April 2010, 19:18 »
euro car parts had one on the shelf for me the other day.
about 15 quid including VAT. but make sure you get the right one. there are two simular
Offline Reasty
  • Alpine white valver.
« Reply #7 on: 10 April 2010, 20:12 »
It is a breather pipe,I would also follow that pipe to where it goes into the block as it splits at the bottom aswell,take the U pin out and just check the pipe over,I've just replaced that whole breather hose on my 8v and it was nearly 40 quid from vw,the part number is written on the bottom  :smiley:
Offline bmw156
« Reply #8 on: 10 April 2010, 20:38 »
yeh mine had split at the bottom as well.
i got quoted about 45 for just the bottom pipe tho
« Reply #9 on: 10 April 2010, 20:48 »
Yes breather hose and it is one piece
Last time I priced one is was around £21 + vat.
« Last Edit: 10 April 2010, 20:49 by Wayne »
