Author Topic: ABS Light on - Vag-Com says Communication Error?  (Read 1751 times)
billabong
« on: 08 April 2010, 19:50 »
Hi peeps,
Anybody have any ideas what could be wrong?
Please see the below Vag-Com report
Many Thanks
Will
VAG-COM Version: Release  311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01     -------------------------------------------------------
   Controller: 037 906 025 A
   Component: SIMOS 4S           1823
   Coding: 00003
   Shop #: WSC 10001
No fault code found.
Address 03     -------------------------------------------------------
   Controller:
   Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 25     -------------------------------------------------------
   Controller: 1H0 953 257  B
   Component: IMMO VWZ3Z0S0058874 V00
   Coding: 09600
   Shop #: WSC 00000
End   -------------------------------------------------------
Offline javalin
Re: ABS Light on - Vag-Com says Communication Error?
« Reply #1 on: 09 April 2010, 16:53 »
bad ground(s) on the ECU(s), or bad comms wiring to the ABS ECU.  I would suspect its after the normal ECU (in the scuttle tray) or you'd have problems with both.  Probably worth checking at the ABS ECU end first.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Lukeabercynonnoi
« Reply #2 on: 15 April 2010, 00:59 »
Might be worth a try :S But lift the rear seats up and make sure that the both ABS sensors are plugged in :S
