Author Topic: why not to buy a cheap ebay (R-spec) diverter valve  (Read 4508 times)
jamie16v
thought i would open it up and see if i would be able to put a better spring in or fit a shim and look...  :angry:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: why not to buy a cheap ebay (R-spec) diverter valve
« Reply #1 on: 07 April 2010, 21:47 »
Might be nothing wrong with the valve itself - try a Forge spring inside it!  ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline T_J_G
« Reply #2 on: 07 April 2010, 21:48 »
Damn
Are the springs same size as Forge?
jamie16v
« Reply #3 on: 07 April 2010, 21:51 »
not sure if theyre the same size tbh.. really odd how this still held boost quite well..
Offline T_J_G
« Reply #4 on: 07 April 2010, 22:11 »
Measure the spring and we shall find out
jamie16v
« Reply #5 on: 07 April 2010, 22:15 »
okies will do...
jamie16v
« Reply #6 on: 07 April 2010, 22:31 »
right, it`s 35mm dia by approx 45mm length not compressed  :nerd:
thanks, jamie.
jamie16v
« Reply #7 on: 08 April 2010, 20:23 »
anyone found out the sizes of the forge springs?..
Offline aaran
« Reply #8 on: 08 April 2010, 20:44 »
if you want to know if its the same a a forge unit you need to measure the spring rate a certain compressions and find out what the coil bind depth is at.
iv seen valve springs that are twice as thin as oem ones that give greater seat pressure at all compressions compared to the oem springs, the same applies to anti roll bar, a 22mm eibach could be harder than a 24mm oem one for example. its all about how they are made and what they are made of ;)
jamie16v
« Reply #9 on: 08 April 2010, 20:56 »
at the moment i couldnt give a sh!t how its made and how it works, i just want it to work.. i have put the bosch one back in for now and its not holding vac or boost like the r-spec one did when it was broke.
i know that the forge ones are rated well, so if one of them fits dimensionaly and it holds boost then jobs a goodun.
