Car audio
FLI amp and sub
Topic: FLI amp and sub (Read 2364 times)
jonesltd
MK7 R
FLI amp and sub
05 April 2010, 19:18 »
Ok Yes its a fli amp and sub - was space saving mainly when I got it but anyway, after having it for just over a year I cannot get any power at all from it? No green light or nothing. It cant be dead can it?
If you cant find it......Grind it
jonnypolish
t2871r needed :)
Re: FLI amp and sub
05 April 2010, 19:53 »
Is it wired up correctly?
MK2 VR y0!
jonesltd
MK7 R
Re: FLI amp and sub
06 April 2010, 18:19 »
It used to work then all of a sudden wouldnt turn on...
jonnypolish
t2871r needed :)
Re: FLI amp and sub
06 April 2010, 18:41 »
check all wiring mate, could be your earth or a dislodged live?
Has your HU been reset? could have been reset to factory which then does not recongnise the sub!
MK2 VR y0!
jonesltd
MK7 R
Re: FLI amp and sub
07 April 2010, 10:05 »
cheers will check all and if not probably time for a new sub
jonnypolish
t2871r needed :)
Re: FLI amp and sub
07 April 2010, 10:16 »
Good luck with it mate and let me know
MK2 VR y0!
jonesltd
MK7 R
Re: FLI amp and sub
Reply #6 on:
09 April 2010, 10:13 »
put it back in the car and re-wired it, a m8 of time old me to put some tester on the connections and they are fine so I can only think its the wire from the battery? but also that fuse in the clear casing appears to be fine? so confused?!
jonesltd
MK7 R
Re: FLI amp and sub
Reply #7 on:
11 April 2010, 13:03 »
I believe its been confirmed thats mine has died as even when I replace a cable to tell the HU to turn on the amp/sub it still wont turn on so my next question is can I just buy a fli amp...sounds stupid and I know they are all built in but you can unscrew it at the back.
Last Edit: 11 April 2010, 14:38 by jonesltd
jonnypolish
t2871r needed :)
Re: FLI amp and sub
Reply #8 on:
11 April 2010, 20:25 »
Shame to hear that its knackered mate
To be honest, i wouldn't waste your money on another FLI product, just go for a small vibe CBR or something?
Better value for money in my opinion, or even try another brand!
MK2 VR y0!
Car audio
FLI amp and sub
