Author Topic: Rear brake bias  (Read 8294 times)
Offline gazpowells
Rear brake bias
« on: 04 April 2010, 20:12 »
hi
I would like to run my car without the ABS but have a problem!
have just unplugged the sensors so the ABS will not work, just went out for a drive and there was to much rear brake bias   :sad:
couldn't brake hard coz the the rear just kept locking up...
the car is a  mk3 16v which i believe the brake bias is controlled via the ABS system..
so how do i control rear bias,  do i have to fit an inline valve into the rear brake pipes? or is there any other way around the problem?
thanks in advance
Offline Paul86S2
Re: Rear brake bias
« Reply #1 on: 04 April 2010, 21:00 »
Try some better pads in the front and standard ones in the rear.
I run mine without the abs, mintex 1155's on the front and standard on the rear. My car has all the weight taken out of it and its really light on the back and it brakes fine.
Worth a try before you start messing with bias valves etc.
Paul
Offline Diamond Hell
  • Opinions я Us
Re: Rear brake bias
« Reply #2 on: 04 April 2010, 23:13 »
If you're going to fit a bias valve you need to appreciate what you're in for: A complete re-wire of the braking system.
I only fitted mine because I had to re-do the whole back end of the car anyway.
Your car should currently have diagonal-split brakes, for safety.
If you fit a bias valve then you're wiring the two front brakes into the two front ports of the master cylinder and then both rears on to a single port on the rear.
Totally different.
Offline gazpowells
Re: Rear brake bias
« Reply #3 on: 05 April 2010, 20:55 »
Paul
have you taken the abs pump out mate or just removed sensors?
Offline Paul86S2
Re: Rear brake bias
« Reply #4 on: 05 April 2010, 21:55 »
I just pulled the fuse.
The abs didn't work before and it comes up with a pump fault on vagcom.
Removing the sensor wires will have the same effect.
Paul
Offline gazpowells
Re: Rear brake bias
« Reply #5 on: 05 April 2010, 22:02 »
thanks  paul
i would like to remove the ABS pump, so i think i will change all the pipes and fit a bias valve
any advice about doing this before i start
Offline gazpowells
Re: Rear brake bias
« Reply #6 on: 05 April 2010, 22:06 »
Totally different.
thanks mate
think i will change all the pipes, should i fit 2 bias valves or just 1 and blank off the 1 rear brake pipe coming out the master cylinder?
im assuming the cylinder has 4 ports
« Last Edit: 05 April 2010, 22:14 by gazpowells »
  • Opinions я Us
Re: Rear brake bias
« Reply #7 on: 05 April 2010, 22:40 »
Blank off the port and fit one, or you'd never balance it out.
Offline gazpowells
Re: Rear brake bias
« Reply #8 on: 07 April 2010, 06:48 »
I had a look at removing the ABS pump last night and the master cylinder only has 2 ports not 4
so do i just use the front port for the front brakes with a t peice in it  and the back port for the rears
or should i change the master cylinder?
thanks guys
  • Opinions я Us
Re: Rear brake bias
« Reply #9 on: 07 April 2010, 13:38 »
One port for the fronts and one port for the back, with the bias valve reducing the flow to the rears.
