Author Topic: Rear brake bias  (Read 8296 times)
Offline gazpowells
Re: Rear brake bias
« Reply #10 on: 07 April 2010, 19:33 »
thanks mate thats what i was thinking  :smiley:
just 1 more question do you know what size the fittings are for the MS? want get all the bits and pipe ready so i can you
a quick swap
thanks
Offline Diamond Hell
  • Opinions я Us
Re: Rear brake bias
« Reply #11 on: 07 April 2010, 22:05 »
Sorry, not off the top of my head.
If I was doing it I'd get them from VW, as the OEM ones will fit up correctly.
Buy kunifer pipe rather than copper, or stainless if you're feeling reet posh.
Offline gazpowells
Re: Rear brake bias
« Reply #12 on: 07 April 2010, 22:11 »
will pop down vw in morning and see if they can help  :smiley:
thanks DH
Offline golf-sib
  • Турботазик
Re: Rear brake bias
« Reply #13 on: 10 April 2010, 04:25 »
Alternatively download the brochure from "Goodridges" website, that has all the nozzle part numbers and materials available to you if you do re-do the brake cables from scratch, longer straight routes could be done with a long thin copper pipe with the correct fittings on as the flexible stainless steel links are only really for the calipers as the wheels bound about.
For that I think it might be worth contacting "C & R Enterprises" as they are the only people that do copper piping for the rear mk4 setups as far as I am aware off.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
  • Opinions я Us
Re: Rear brake bias
« Reply #14 on: 10 April 2010, 08:31 »
You've mis-interpreted what I've said.
Flexible stainless pipe is indeed only to go from the car to the wheel.  Stainless hardlines (kinda like the steel OEM lines) do the stuff around the car body and are the most durable and damage resistant, hence my mate's using them on his off-road racer.
OEM routed copper pipe won't work in this installation as it'll be a rather different set up - instead of two pipes going backwards, there'll be one.  The front pipes will go a different route, too.
Kunifer is more durable than copper, which is why I recommended that instead of straight copper.
Offline gazpowells
Re: Rear brake bias
« Reply #15 on: 10 April 2010, 21:05 »
my local motor shop is making my pipes up this weekend and i should have them monday...
and its going to be Kunifer pipe..
they doing all the hard work for me ( fittings and flares ) so i just gotta shape them,  fit them and bleed the system and hopefully
everything will be good  :smiley:
Offline gazpowells
Re: Rear brake bias
« Reply #16 on: 10 April 2010, 21:07 »
i did try my local VW but they was not much help  :sad:
