Author Topic: SORTED :) Front Washers Failed.  (Read 2324 times)
Offline braderz
« on: 02 April 2010, 17:07 »
I got my car back from bodyshop yesterday, having had a new driver door. Been out in it today only to find the front washers do not work. They worked perfectly fine a week ago when i dropped it off, but now nothing. The wipers still go, and the washer works on the rear, as well as the wiper. The tank is full, the fuses are fine. When attempting to use the washers the motor doesnt even run. Easy fix?
« Last Edit: 03 April 2010, 15:05 by braderz »
Offline richw911
Re: Front Washers Failed.
« Reply #1 on: 02 April 2010, 17:13 »
Try a new fuse EVEN if it looks ok.
Washer Pipe come off?  :undecided:
Offline braderz
« Reply #2 on: 02 April 2010, 17:25 »
Checked the pipes all ok and no leaks. Fuses swapped and tested, still an epic fail. Bit strange how its come back to me like this though, never had any problems. Im wondering, by a long shot, if its something to do with the wiper stalk wiring, and whether or not its plugged in down by the accelerator pedal, and this is where the loom for the door thats just been replaced is plugged in.....  But then the rear washer works..... lots of muck on the road atm and screen is grubby :(
Offline richw911
« Reply #3 on: 02 April 2010, 17:27 »
Hmmm is the wiring connector on the pump fully  :undecided:
Offline braderz
« Reply #4 on: 02 April 2010, 17:49 »
yep thats on... what a bugga this is  :rolleyes:
Offline richw911
« Reply #5 on: 02 April 2010, 17:53 »
Get a multimeter and get someone to press the washers on to see if power is at the plug on the pump  :smiley:
Offline braderz
Re: Front Washers Failed.(update)
« Reply #6 on: 03 April 2010, 11:05 »
Right ive plugged my washer motor into my brothers golf this morning its working fine, so it confirms an electrical issue somewhere on my car, the wiper stalk maybe?
Offline richw911
« Reply #7 on: 03 April 2010, 11:08 »
I would say or as you said loose connection somewhere in the car  :undecided:
Offline braderz
« Reply #8 on: 03 April 2010, 11:18 »
FAIL. lol ok where do i start, sledge hammer for the dash?
Offline richw911
« Reply #9 on: 03 April 2010, 11:25 »
Does everything else work?
Maybe somthing the bodyshop have done  :undecided:
