Author Topic: SORTED :) Front Washers Failed.  (Read 2325 times)
Offline braderz
( Fixed) Front Washers Failed.
« Reply #10 on: 03 April 2010, 15:04 »
Turns out i was nearly right. The offending item was the plug that the door loom goes into (behing the panel where bonnet release is) i unplugged it, and the pump worked, back in, didnt work, cleaned the contacts up a bit, all is well now!! although half the dash had to be taken off to get to it! Least it didnt cost me again!!
Offline richw911
Re: SORTED :) Front Washers Failed.
« Reply #11 on: 03 April 2010, 17:17 »
Glad thats sorted   :smiley:
Offline mattkh
Re: ( Fixed) Front Washers Failed.
« Reply #12 on: 03 April 2010, 17:31 »
.....Turns out i was nearly right. The offending item was the plug that the door loom goes into
Hi
I wonder if there is any point in telling the body shop this.
May be an idea, next time they unplug/plug in  a wiring plug from the door of a customer's car, they should check things like the wing mirrors, speakers,...windscreen washer.
Offline braderz
« Reply #13 on: 03 April 2010, 18:28 »
Hi
well thats the weird thing, the door electrics fully worked....
