Author Topic: Xenons  (Read 7768 times)
Offline gizzywizzy
Xenons
« on: 02 April 2010, 14:18 »
Well I've had the car since July but didn't realise that the GTI has adaptive headlights.
My xenons go through a little warm up routine every time I switch on but I don't think that they move when cornering as some other xenon owners seem to indicate.
Can someone guide me in the right direction so that I can check if mine do move with the car.
Thanks
Gizzy
P.S.  HAPPY EASTER TO YOU ALL :smiley:
Offline Snoopy
  • Moderator
  • Geoff.
Re: Xenons
« Reply #1 on: 02 April 2010, 14:36 »
Theres an option in the MFA display you have to tick.
Its under assistant bend lighting.
How easy is it too see the lights dance as i have not yet :undecided:
« Last Edit: 02 April 2010, 14:38 by Snoopy »
Garage:
35+ years of GTI ownership.
Offline gizzywizzy
Re: Xenons
« Reply #2 on: 02 April 2010, 14:48 »
Hi
As soon as you switch on the ignition the lights go up and down and out to the side then back in.  It's a dead neat trick and gets plenty of attention from other drivers.
Thanks for the info will go out and try it soon.
Gizzy
Offline Snoopy
  • Moderator
  • Geoff.
Re: Xenons
« Reply #3 on: 02 April 2010, 15:19 »
I will have to check mine, as mine i don't think seem to do that. This might explain the strainge 2 long beeps and a relay click under the bonnet after i turn the car off.
Garage:
Offline VWKev
  • Please Support Non-Human Rights
Re: Xenons
« Reply #4 on: 02 April 2010, 15:27 »
Best option I have spec'd for the car, the Xenons make me dribble sex wee. That trick that they do with the side movement and up/down movement at start up is well good, and as Gizzy says you do get lots of looks.
I can confirm mine do move as I'm turning corners and dip etc as i go up and down hills. I didnt have to set anything in the MFD maybe mine were already set.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline gizzywizzy
Re: Xenons
« Reply #5 on: 02 April 2010, 17:48 »
Well I've had a look in the handbook and it says car has to be travelling at 10kph and on dipped beam then they will light up on cornering etc, so will have to go for a run after dark and give them a test.  Cheers Kev
Gizzy
Offline H12
Re: Xenons
« Reply #6 on: 02 April 2010, 18:09 »
Mine do their little aerobic work out every time I start the car- I love it  :smiley: :smiley:
Offline Snoopy
  • Moderator
  • Geoff.
Re: Xenons
« Reply #7 on: 02 April 2010, 18:11 »
I better check mine then as i cannot see it when in the car. With them against the garage door for example.
« Last Edit: 02 April 2010, 18:12 by Snoopy »
Garage:
Offline H12
Re: Xenons
« Reply #8 on: 02 April 2010, 18:14 »
I'm surprised you can't see them working from inside the car mate- I can from mine so it sounds like they're not working ?
Offline gizzywizzy
Re: Xenons
« Reply #9 on: 02 April 2010, 22:36 »
Snoopy
If you can't see them working from in the car then they can't be working, I can see mine in the bumper of a car parked 4 feet away from mine.  You can't miss their little routine it's ace.
Gizzy
