Author Topic: Engine code issue  (Read 2038 times)
Offline Dannyboy90
Engine code issue
« on: 31 March 2010, 20:47 »
I've read the sticky on engine codes, However I can't find it in any of the places, but what I can find is where a sticker used to be..... im assuming maybe its come off?Any other way to tell what engine it is? :(
Would really appreciate help so i can get quote in map
« Last Edit: 31 March 2010, 20:49 by richw911 »
Offline richw911
Re: Engine code issue
« Reply #1 on: 31 March 2010, 20:49 »
« Last Edit: 31 March 2010, 20:52 by richw911 »
Offline topher
  • Administrator
  • fully functioning
Re: Engine code issue (Please dont lock)
« Reply #2 on: 31 March 2010, 20:53 »
has someone ground off the tag on the front/left of the head? fishy!
if your throttle body is cable operated then it's agu.. if not then it's a later one with bosch me7.5 management. aum/arz/auq remaps usually cost the same, agu is usually a bit cheaper.
Offline Dannyboy90
« Reply #3 on: 31 March 2010, 20:59 »
It's 1999,
I think its AGU..
Yes its driven by a cable.... because my friend was jealous, said his is "computer driven" and would rather have a cable.
I have no idea, im not a petrol head :(
So you think its AGU? :)
Offline richw911
« Reply #4 on: 31 March 2010, 21:01 »
It's 1999,
I think its AGU..
Yep  :smiley:
As toph says has the code been ground off?
Offline Dannyboy90
« Reply #5 on: 31 March 2010, 21:03 »
Oh, i guess not, I dont know, I wasnt 100% sure what i was looking for, I looekd all over, but couldnt see anything, nor could my mate.
It's cool though, thanks for the advise.
Question, the remap, how long does it take? Like do they need to just connect to the ECU? or take it out etc?
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 31 March 2010, 21:06 »
Depends where you go. Some places take the chip out still, others use obd flash tools. Occasionally the chip has to come out anyway if the flash writes are unsuccessful.
Offline richw911
« Reply #7 on: 31 March 2010, 21:07 »
R tech can now do an AGU through the OBD port  :wink:
Takes mins as long as your car is in good order / no fault codes  :smiley:
**Edit beat by toph  :laugh:
Offline Dannyboy90
« Reply #8 on: 31 March 2010, 21:07 »
Ok, so if they leave it in and flash it, how does that take?
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 31 March 2010, 21:08 »
depends where you take it. usual rtech process takes 90 minutes - 2 hours with the dyno runs and diagnostics.
