Author Topic: CD Player Doesnt Come On When Ignition Is On  (Read 1721 times)
Offline RandGTi
« on: 30 March 2010, 21:01 »
Ok so when my Gti isnt on and the ignition is off the cd player runs and when the key is at the 1st click the cd player runs then as soon as the ignition is on.....Nothing, i dont have a clue what it could be, any help out there would be great....
Offline troublestarter
Re: CD Player Doesnt Come On When Ignition Is On
« Reply #1 on: 30 March 2010, 21:38 »
sounds like the ignition live is connected to the wrong wire at the ignition switch
if someone has run a cable from the thin brown/red wire at the ignition switch to the red ignition live of the stereo theres your problem it needs to be connected to the black wire at the ignition switch instead
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline RandGTi
« Reply #2 on: 30 March 2010, 21:45 »
How do i sort that out then? get into the ignition barrel?
« Reply #3 on: 30 March 2010, 23:27 »
you don't need to get into the barrel there is a large black plug on the end of it and it can be found there
you can even find it in the loom coming from the steering column heading towards the fuse box
Offline RandGTi
« Reply #4 on: 31 March 2010, 00:12 »
ideal ill have a bash at it 2moza, cheers
