Author Topic: porsch calipers picked up  (Read 1884 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 30 March 2010, 15:29 »
Just picked these boxster s rears up for 190 pics dont do em justice theres good meat on the pads and overall condition is quite good no need for refurb or re- lacquering just need to get the adapters now (in post) and Lines off dave b then good to go..
<<<Big Build Thread>>>
Offline Waffs1984
  • Spacers are for chumps...
Re: porsch calipers picked up
« Reply #1 on: 30 March 2010, 15:52 »
Daft question but i assume Boxter rears are going on the rear of your golf?
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
« Reply #2 on: 30 March 2010, 15:53 »
I'm guessing front
Offline nadlad
« Reply #3 on: 30 March 2010, 15:54 »
goign on fronts just makes u wonder how piss poor the overall power of a golf is when the rears of a porsche are gonna be used as the fronts of a golf
Offline Waffs1984
« Reply #4 on: 30 March 2010, 16:48 »
I thought i'd read this somewhere but thought i was going nuts!
So i need to hunt for boxter rear calipers on ebay then? Are the boxter fornts too big to fit or something?
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #5 on: 30 March 2010, 16:53 »
would be good if you could post up the cost of the Mounts for the caliper, brake lines and what size disc's your going to use and cost.
Offline Waffs1984
« Reply #6 on: 30 March 2010, 17:04 »
Don't you run these on 312mm discs? The adapters can be had off ebay for about the same as a set of 312mm carriers I think. Correct me if I'm wrong as I want to do this upgrade at some point!
Offline Steve_PD
« Reply #7 on: 30 March 2010, 17:35 »
Carriers are about £120
you can run 312mm discs or 325mm discs
Offline Waffs1984
« Reply #8 on: 30 March 2010, 18:08 »
I assume the disc size depends on what adapters you get?
Offline Steve_PD
« Reply #9 on: 30 March 2010, 18:28 »
no same carrier. you use some spacers/shims behind the carrier to make it clear the larger discs
