Author Topic: Oil cooler  (Read 1731 times)
Offline Volkswagavin
Oil cooler
« on: 15 November 2004, 13:45 »
My MK2 Gti 8v doesn't have an oil temp sender sprouting from the oil cooler, instead one of the holes is blanked off and the other has the pressure sensor.
I have a loose wire in the engine bay to connect a temp sender to the MFA but nowhere to connect it!
Is it a big deal to replace the top of the oil filter/cooler mounting to one with two holes??
The engine was replaced about a year ago, so I guess the mechanic put the wrong part on??
Gav
Mk2 Golf GTI 8v - J reg
Veedubgt18v
Re: Oil cooler
« Reply #1 on: 16 November 2004, 09:53 »
no its not that hard, but you could get a t piece from a performance motorsport store (i got mine from big boys toys) like this
that would be easier, other than that its just an unbolt then bolt back on job
Veedubgt18v
Re: Oil cooler
« Reply #2 on: 16 November 2004, 09:55 »
the brass bit by the way!
Re: Oil cooler
« Reply #3 on: 16 November 2004, 11:44 »
Sounds like the filter housing is from a Carb engine, they don't have the extra hole needed.  If you plan to change your oil at some point get a GTI filter housing from a scrappy and chuck it on there!
Re: Oil cooler
« Reply #4 on: 16 November 2004, 12:45 »
That would explain it I guess.  Is it just the filter housing I have to buy or does the oil cooler come attached to it??
Gav
Re: Oil cooler
« Reply #5 on: 16 November 2004, 13:18 »
The oil cooler is seperate from the housing, held on with a nut.
