Author Topic: Problems with my MK4!!!  (Read 853 times)
Offline Mike_MK4
« on: 26 March 2010, 15:57 »
Having problems with my MK4 and I can see that i'm not alone!!!
1st, the Reverse Lights stopped working, changed the bulbs but nothing happening.
Then the indicators stopped working but they did work when i used the hazzard buttons. This then stopped after 2-3 flashes!!
But it does still flash when i lock & unclock the car with the remote key fob!!! Now...1 get one flash on the hazzard, and when the alarm set/resets!
The rear suspension bushes have gone and the exhaust has come loose underneath ( doesnt blow, sound different or hang low at all) so need to get it reattached in the centre section this weekend.
The screen detailing MPG, temp etc has started (1-2 per week) not coming on when I switch on the ignition so i have to stop, switch it off & back on again and it miraculousy works again!
any ideas about how much it would cost to fix this?
A friend recokons the electric fault might be the relays??? or switches as they supposedly common on these models?
Offline johnson6672
Re: Problems with my MK4!!!
« Reply #1 on: 26 March 2010, 16:02 »
Reverse lights will probaley be the wiring at the switch on the gbox
http://www.golfgtiforum.co.uk/index.php?topic=87373.0
Have a look here there is some info about it.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Rhyso
« Reply #2 on: 26 March 2010, 16:05 »
Hazard switch has gone I suspect - new switch is about £30 from the dealers - you replace the whole switch  :smiley:
Offline Mike_MK4
« Reply #3 on: 26 March 2010, 17:31 »
Thanks for this...will get these looked at tomorrow.
« Reply #4 on: 27 March 2010, 00:06 »
Reverse lights could be down to the switch.
