Author Topic: why does it not have one ?  (Read 1416 times)
Offline boxer1968
« on: 21 March 2010, 20:00 »
hello all
ive just bought a mk 2 5door 16v  (1992)i think its atlas grey got it cheap! as i know  you guys know onions :smiley: . thought id ask a couple of questions on few points. have spent the day fixing both ft electric windows ,sorted a bkn rear wiper motor and replaced rear seat belts ,removed sigma alarm that was fitted (insurance company not reconising it),hoping to fit a suitable one at the weekend. my question is my isv has no plug  fitted to it have looked round enginge bay for it, its not there so been cut or removed plus after looking in haynes manual as i didnt know its name i have no overrun cut off valve or associated componets ie pipes or a plug to connect too,i have a donor car that i dont want to have to have somone remove and replace engine with ,is it a case of finding a loom with cut wires in?
Offline Toby
  • Car - less
Re: why does it not have one ?
« Reply #1 on: 21 March 2010, 20:29 »
I can't help on your questions but I lived in crawler for 12 years and now live in burgess hill and today brought a mk 2 gti I think in atlas grey 3 door :) and hopefully doing a engine conversion :) good luck mate
Toby
Currently down under
Offline boxer1968
« Reply #2 on: 22 March 2010, 00:09 »
thanks mate :smiley:you too
« Reply #3 on: 22 March 2010, 11:36 »
is it definitly an original 16v, since all the bits you mention are missing that makes me wonder if its had an engine swap from an 8v?
Offline boxer1968
« Reply #4 on: 22 March 2010, 17:20 »
ok thanks rubjonny that covers that answer checked on askmid site has it listed as a 8v what can i do to sort it ? it has a 16v engine in it now
Offline Sam
  • Sam I am
« Reply #5 on: 22 March 2010, 17:23 »
Go to the guy you bought it off and sh!t in his bed
« Reply #6 on: 22 March 2010, 18:29 »
if it runs alright now id not worry too much about it. if you were really bothered what you would want is the complete engine loom from a 90 onwards 16v, plus the ISV control unit from behind the console and wiring from that to the plugs on the engine loom. the over-run valve behind the airbox stops the car cuting out when you dip the clutch at high revs, and the other metal valve adds a bit of fuel if you floor it when cold.
Offline boxer1968
« Reply #7 on: 22 March 2010, 19:18 »
i have  a 16v 90 spec car that i can strip if need be for the parts required just didnt want to strip a car if i didnt have to was hoping to sell the other one on the forum at a later date as a project for someone guess il keep for spares ,thanks again
« Reply #8 on: 23 March 2010, 13:24 »
is this car going to be a keeper as is, or do you fancy an engine swap in the future?  If you fancy a better engine in the future then I'd be tempted to live with it as is, plenty of MK1 16v conversions with the above bits missing. generally the 16v will run alright with the above missing once warmed up, from cold they can be a bit fussy but rasing the idle can help.  If its going to be kept as is for the long term then I would be stripping the other 16v for the proper bits. If you fit all the bits off this car back to it then it'll still be a runner after all!
Offline boxer1968
« Reply #9 on: 23 March 2010, 18:56 »
i do intend to keep the car wont be doing anything fancy in future to the engine, just want the car to run right, going to try sourceing all the bits needed to sort out running issues if not il strip other car. thanks for the advice.max
