Author Topic: Help!!  (Read 2930 times)
Offline boyob32
  • 1.8T
Help!!
« on: 18 March 2010, 14:02 »
Recently when i started up the car the temp sign would flash before finally going off. I was planning on changing the coolant reservoir...
However whilst driving today it began flashing and the temp rose to 130. After stopping the car, i popped the bonnet and the coolant level was high and bubbling...i have searched and think it's the worse case scenario, however what can i check regarding alternative problems??
Offline darren1.8t
  • I HATE FRENCH CARS
Re: Help!!
« Reply #1 on: 18 March 2010, 14:05 »
stuck thermostat?? water pump or head gasket?? check the oil cap to see if the oil is milky? if your worried about head gasket then a garage can use a special tester which tells you if the head gasket has gone? but check the themostat first  :huh:
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #2 on: 18 March 2010, 14:08 »
Where abouts is the thermostat located and how can i test it??
Offline northeast_gti-t
  • "1.8T AGU"
Re: Help!!
« Reply #3 on: 18 March 2010, 14:13 »
2000 Mkiv GTi 1.8T AGU
Offline darren1.8t
Re: Help!!
« Reply #4 on: 18 March 2010, 14:15 »
thats the cheapest and easy option m8 if not the could be head gasket  :undecided: let us no how ya get on good luck
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #5 on: 18 March 2010, 14:25 »
what can i look for to check the head gasket?
Offline darren1.8t
Re: Help!!
« Reply #6 on: 18 March 2010, 15:46 »
heater not working or look in the oil filler cap to see if the oil has gone milky colour? if not check to see if the water bottle is getting pressured up!
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #7 on: 18 March 2010, 17:42 »
getting my mate to plug it in on Sat.
Just checked it out, clear liquid in the coolant tank and the oil looks fine. No temp light on start up and no signs of bubbling coolant!
Fingers crossed for the thermostat  :embarassed:
Was getting it serviced on sat but im thinking the money will be spent elses where.....
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #8 on: 18 March 2010, 20:30 »
quick update and question!  started it up and let it warm. Barely boy heat come into the car through vents. Also the pipe coming from the thermostat was hot but the pipe from the bottom of the radiator was cold? Any suggestions?
Offline mick ov mids
Re: Help!!
« Reply #9 on: 18 March 2010, 20:40 »
i some times have the same problem with mine i.e the temp light flashin and beeping its balls of on start up but i think mines down to changing my air filter to a k & n typhoon becos i never had this problem when the standard airbox was fitted, atm im not to concerned about it as my oil is clean, im sure this cud also be down to a dodgy sensor? could be wrong tho so dont quote me on that  :drool:
[img width=500 height=200]http://i836.photobucket.com/albums
