Author Topic: Help!!  (Read 2933 times)
Offline richw911
Re: Help!!
« Reply #10 on: 18 March 2010, 20:43 »
i some times have the same problem with mine i.e the temp light flashin and beeping its balls of on start up but i think mines down to changing my air filter to a k & n typhoon becos i never had this problem when the standard airbox was fitted, atm im not to concerned about it as my oil is clean, im sure this cud also be down to a dodgy sensor? could be wrong tho so dont quote me on that  :drool:
That will be the metal sensor in the expansion tank  :wink:
Offline mick ov mids
Re: Help!!
« Reply #11 on: 18 March 2010, 20:52 »
yeh kinda had a feeling it would have something to do with that , is there a was of stopping the temp light other than replacing the standard box back on?
[img width=500 height=200]http://i836.photobucket.com/albums
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #12 on: 19 March 2010, 01:53 »
i assume that wouldn't cause the major overheating i had?
Offline darren1.8t
  • I HATE FRENCH CARS
Re: Help!!
« Reply #13 on: 19 March 2010, 06:52 »
no m8 you need to let it get really warm and see if the themostat is opening? this could be why the bottom hose is not getting hot! but you need to let the engine get hot for the themostat to work! also while the engine is running just leave the heater on hot but not with the heater blowing! but i would deffo try ya themostat first  :cool: good luck
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #14 on: 19 March 2010, 09:57 »
I'll be on it today! cheers
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #15 on: 19 March 2010, 10:02 »
In fact another question, if i can't tell due to incompetence, when it gets plugged in tom, i assume if it is the stat it will pinpoint that fault?
Offline darren1.8t
Re: Help!!
« Reply #16 on: 19 March 2010, 12:04 »
erm im not to sure??? it mite do  :huh:
Offline northeast_gti-t
  • "1.8T AGU"
Re: Help!!
« Reply #17 on: 19 March 2010, 12:24 »
i dont think it will  :wink: the only fault codes you will get refer to the coolant temp sensor and they usually have the normal fault code number and it will say error in mapped cooling system iirc
2000 Mkiv GTi 1.8T AGU
Offline gerlewis
Re: Help!!
« Reply #18 on: 19 March 2010, 12:25 »
sounds like the thermostat is stuck closed (probably given up the ghost).
Open up the housing, take it out, and stick the housing back on.
Then top up any lost water, and go for a spin. You should find the car struggles to get warm, but works fine.
You can live like this until you get a new thermostat.
Offline boyob32
  • 1.8T
Re: Help!!
« Reply #19 on: 19 March 2010, 13:16 »
Will give it a go! Thanks to all!
Will update any results!
