Golf mk4
Wazzzer
car feels hesitant sometimes
Topic: car feels hesitant sometimes (Read 2134 times)
carrington865
17 March 2010, 11:47 »
hi
i have a 2001 aum engin 1.8 t golf. sometimes it feels abit hesitant at low revs and a lil bit spluttery when apply a lil bit of throttle. its ok wen put foot down
and ideas as to the cause other than leads/plugs?
cheers
007p diverter, piper x panel filter, R-tech remap... and the addiction begins
Hulmie
White MK4 1.8T AGU K03s
Re: car feels hesitant sometimes
17 March 2010, 11:54 »
Start off by giving the Throttle body a clean. Details of How To in the maintainence section.
Try this and see if it makes a difference. And go from there
carrington865
17 March 2010, 11:57 »
cheers il give that a go. is there anythin to look out for sensor wise. i ready in a thread once a guy had splutter issues and turned out to ba a sensor
radz
GTI forum regular
17 March 2010, 12:00 »
I had a similar issue, my lambda sensor had gone but I think you would have a few more symptoms, car is running very rich and a very strong smell, poor mileage etc.
If you have a garage near you take it for an emissions test?
Last Edit: 17 March 2010, 12:06 by radz
carrington865
17 March 2010, 13:00 »
i did 200 miles to 35 litres of fuel dunno if that about right?
i am gna get a full service done and clean throttle body too then take it from there
5miffy
GTI forum regular
17 March 2010, 15:38 »
MAF?
DaiGTI
GTI forum regular
Reply #6 on:
17 March 2010, 18:32 »
got the same problem mate mines spluttery in low gears my lambder sensor is gone replaceing both of them ull have one either end of your CAT also had mine plugged up and a code came up with loss of pressure between turbo and throtle ull have to check your pipe work around your turbo cracks etc!!
hope it helps
www.vwvortex.com/artman/uploads/04_003.jpg
richw911
10k hero
The Linkmeister and an OEM Freak.
Reply #7 on:
17 March 2010, 18:55 »
Any fault codes?
As said do a TB clean
carrington865
Reply #8 on:
18 March 2010, 07:44 »
Quote from: 5miffy on 17 March 2010, 15:38
MAF?
that was the sensor i read about before. any one know the price of one?
wat is a MAF sensor?
carrington865
Reply #9 on:
18 March 2010, 07:46 »
Quote from: richw911 on 17 March 2010, 18:55
Any fault codes?
no codes that im aware of. no engin manag light or indication on dash
Golf mk4
Wazzzer
