Author Topic: Toad alarm  (Read 5338 times)
Offline dannyboy2501
  • Blackberry IM pin 228D8231
Toad alarm
« on: 16 March 2010, 21:08 »
Just been looking through the threads and can't seem
to find anything on toad alarms the alarm is driving me
mad goes off every couple off minutes it was already on
the car when I bought it no info came with it so I ain't got
a clue is there any way reset it all advice welcome
cheers
Offline javalin
Re: Toad alarm
« Reply #1 on: 16 March 2010, 21:14 »
get it removed and leave just the factory con-log / ECU one.  I did cause I hated it - stupid fob thing
General alarm info here:
http://www.golfgtiforum.co.uk/index.php?topic=110719.0
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline sharki786
  • GOT BOOST??
Re: Toad alarm
« Reply #2 on: 16 March 2010, 22:27 »
could be an indication to your battry on its last leg? or something is triggering it or somthing thats moving infront of the interior sensors? also it would be great if you could point out which series the alarm is e.g Ai606 (the 1 i have) they are pretty good.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Re: Toad alarm
« Reply #3 on: 16 March 2010, 22:33 »
Couldn't tell you fella I got a dark green fob with 2 buttons
lol couldn't tell you anything else
Offline sharki786
  • GOT BOOST??
Re: Toad alarm
« Reply #4 on: 17 March 2010, 13:18 »
hmmm  :huh: do some research, if you cant be arsed then its in ur hands to remove it. this is what i found http://images.google.co.uk/images?um=1&hl=en&tbs=isch%3A1&sa=1&q=toad+alarm+2button+fob&aq=f&aqi=&aql=&oq=&gs_rfai=&start=0 you will find out the model of the alarm,
sorry couldnt be of anymore help.
Sharki
*****MK4 GTI T*****
Christo77
Re: Toad alarm
« Reply #5 on: 17 March 2010, 13:29 »
I was going to say if it's the Ai606 i thought they were known good alarms..
If i can divert a moment..sorry chaps'   sharki, did you have yours professionaly fitted? any probs with draining battery etc..  thinking of getting one of these anyway..
Thanks
Re: Toad alarm
« Reply #6 on: 17 March 2010, 14:38 »
Toad 2 Button Car Alarm Remote Key Fob
Toad Ai600 Mk II Remote Control Fob
 Thats the bugger
Offline troublestarter
Re: Toad alarm
« Reply #7 on: 17 March 2010, 18:29 »
to find what is causing the false alarm follow this procedure
when the alarm has been triggered disarm the alarm and count the number of flashes on the led then refer to the owners manual and that will tell you what caused the alarm to trigger
toad alarms are generally very good reliable alarms i've fitted loads of them over the years and never had any issues with them
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Re: Toad alarm
« Reply #8 on: 17 March 2010, 20:38 »
No owner manual didn't get alot when I bought the car
might just get someone to av a look lol
Offline sharki786
  • GOT BOOST??
Re: Toad alarm
« Reply #9 on: 17 March 2010, 21:53 »
mine is the Ai606 comes with total closure. it has bonnet alarm so if its opened the alarm will go off has anti jack system so when car starts the doors lock in a few seconds and you CANNOT open them from inside without pressing the unlock on the remote. the remote is dark green with 2large buttons at the top and 2small buttons at the bottom.
Christo, it was "professionally" fitted the guy was a D1CK! he didnt have a clue, broke half the bits on my car and then the interior light would not go off eventualy i got fed up, found the wire for the delay interior light, took it off then armed the alarm disarmed it then connected the wire and bobs ur uncle it worked.
its a good alarm but i would recommend a guy from up north area leeds/wakey area to fit it for you, his a top bloke and apparently a few people on here have said his a good bloke who knows what his doing, if you want his number send me a pm. i would get the proximity sensors (when someone gets to close the car beeps and then it will go off) its a good piece of kit too. i also want the comming home lights (fogs turn on when you arm the alarm).
follow troublestarters advise.
sorry 4going on n on n on   :tongue:
hope that helps.
p.s you should be able to download the manual from toads website.
*****MK4 GTI T*****
