Author Topic: GTi Fuel  (Read 11068 times)
Offline Tongey
GTi Fuel
« on: 16 March 2010, 14:30 »
Sorry if this has been posted before. I've just bought a 55 plate GTi and i'm wondering do you have to stick with Super unleaded or can you stick in normal unleaded fuel.
Offline flyingzard
Re: GTi Fuel
« Reply #1 on: 16 March 2010, 15:11 »
it'll take both fine unless it has been re-mapped. If it has then you need to use super
Offline wuker
Re: GTi Fuel
« Reply #2 on: 16 March 2010, 16:13 »
I'd go for the 99RON and the performance is slightly better
MPG is a little improved as well
Offline ub7rm
Re: GTi Fuel
« Reply #3 on: 16 March 2010, 17:37 »
GTI's are mapped for super from the factory so work best with it.  No harm apart from slightly worse power and fuel economy in using normal unleaded.  I think super has slightly better additives and detergents for keeping your engine clean in it as well but probably not that big a deal.
2020 BMW 128ti
2017 Golf GTD Estate
Offline Tongey
Re: GTi Fuel
« Reply #4 on: 16 March 2010, 18:06 »
Thanx for the advice
Offline Chris MKV
Re: GTi Fuel
« Reply #5 on: 16 March 2010, 19:38 »
The small increase in mpg also gives you a slightly improved tank range. This can be useful at times.
I've been a target for 'halfords spec' saxos for almost three years now!
Offline lowdown
Re: GTi Fuel
« Reply #6 on: 16 March 2010, 19:55 »
Shell V power now 99 octane and gives good results.  Stay away from supermarket petrol it's dreadful.
Offline TagnuT
  • Edition 30
Re: GTi Fuel
« Reply #7 on: 16 March 2010, 21:01 »
Always used Shell V power or Tesco 99. Don't forget to get your V power points or club card points too.... :evil:
Some info on 95 Ron Vs 99 Ron.
http://www.thorneymotorsport.co.uk/tuning/Fuel_Test_Results.shtml
« Last Edit: 17 March 2010, 21:16 by TagnuT »
Bye Bye Edition 30
Offline nick30
  • Black Edition 30 DSG
Re: GTi Fuel
« Reply #8 on: 16 March 2010, 21:24 »
i always use VPower with or without a map. it may cost a couple of pence more but it will even out with the extra mileage and confidence your engine is getting what it deserves. my misses uses VPower Diesel and has reported better performance and mileage too  :smiley:
if you actually give a toss about your car i would say look after it dont feed it turkey twizzler fuel  :shocked:
on the fuel filler cap it states the fuel that needs to be in it i think its 98 or 99 but will check tomorrow  :nerd:
Offline FamilyDub
Re: GTi Fuel
« Reply #9 on: 16 March 2010, 22:31 »
Fuel cap says 98 :nerd:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
