Author Topic: GTi Fuel  (Read 11090 times)
Offline FamilyDub
Re: GTi Fuel
« Reply #20 on: 18 March 2010, 15:09 »
^^^ Backing up Alan on this one. Talked to death elsewhere, though.
MKV: designed to run on 98+, will be ok on 95.
MKVI: designed to run on 95, better fuel will give decent gains, compared to MKV.
The FSI tech post would have been posted by ub7rm, maybe?
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Egbutt Wash
Re: GTi Fuel
« Reply #21 on: 18 March 2010, 15:58 »
What I do notice is that Morrisons petrol gives worse mpg than ordinary Shell.
Currently digging a bunker.
Offline ub7rm
Re: GTi Fuel
« Reply #22 on: 18 March 2010, 16:15 »
As you wish sir  :grin:
Regards FSI owners mainly.
The higher the octane rating of the fuel the longer the FSI engine will run in FSI mode.
You see, when the FSI is running in 'Fuel Stratified Injection' mode it creates a lot of NoX (NoX - Very bad as far as emisions go) due to it being such a lean burn, so it has a NoX Cat which abrorbs the NoX, once its full the Nox probe (fancy lambda probe) senses this and the engine switches back to normal running and can safely clear the NoX out with the other gases through the main Cat so it can switch back into in FSI mode again.
The problem with octane levels is, and this is just an example depending on driving styles.
Out of 100 miles average :-
95RON - 90 miles normal, 10 miles FSI (lots of NoX made in FSI mode)
97+RON - 60 miles normal, 40 miles FSI (some NoX made in FSI mode)
Now regardless of what anyone says this is how the engine is built and as its more efficient in FSI mode VW always recommend the highest octane rating for this reason, they did introduce a 1.4FSI for the uk market that is made to run on 95RON fuel for longer but you want to see the size of the NoX Cat, more like a tanker. lol
And after all that, you will get better miles to the gallon running 97+RON regardless of it being an FSI, its they way they are made these days, the ecu recognises when the fuel mixture combusts and will adjust it accordingly, the cheaper the fuel the more retarded the timing, the more retarded the timing the less power, the less power the more you 'need' to put the foot down.
Its part of the GTI hints and tricks thread in the maintenance section ...
2020 BMW 128ti
2017 Golf GTD Estate
Offline ub7rm
Re: GTi Fuel
« Reply #23 on: 18 March 2010, 16:16 »
I believe Morrisons fuel contains more biofuel than most other petrol ...
2020 BMW 128ti
Offline Egbutt Wash
Re: GTi Fuel
« Reply #24 on: 18 March 2010, 16:33 »
What I do find is when I have a full tank of 99 my mpg drops.  Because I drive hell for leather to get my monies worth out of the dear stuff.  I even use the flapsters.
Offline FamilyDub
Re: GTi Fuel
« Reply #25 on: 18 March 2010, 16:58 »
 :grin:
^^^ I notice a performance differential, but no gain/loss in mpg from either.
Although to be fair, my mileage/use is random and erratic, so I wouldn't like to be a test bed...
...unless someone is willing to pay for ten tanks of 99 and ten tanks of 95 to compare...  :evil:  :grin:
Offline AlanD
  • MK5 2.0T 16v
Re: GTi Fuel
« Reply #26 on: 18 March 2010, 17:37 »
Whats you account name, sort code, account number etc and I'll send the monies over . . . .:D
Offline marty341
  • To ko4? or to not Ko4? now that is the question.
Re: GTi Fuel
« Reply #27 on: 18 March 2010, 20:58 »
Markv gtis are superb cars! look after it, and it will look after you :wink:
We all know which it prefers!? V-Power/Tesco Super all day long.
Revo Stage 1
Offline scotland67
Re: GTi Fuel
« Reply #28 on: 19 March 2010, 09:10 »
According to the VW GTI Brochure, page 24, technical notes, 04, "Thanks to the knock control,unleaded four star(at least 95 ron) can be used instead of unleaded super plus"
Offline FamilyDub
Re: GTi Fuel
« Reply #29 on: 19 March 2010, 09:53 »
^^^ which brochure?
