Author Topic: Heater Matrix and Radiator  (Read 2568 times)
Offline drapergti
« on: 15 March 2010, 07:58 »
Hi I am planning on changing the heater matrix and change the radiator in my 1990 16v, I'm going to buy the MK3 one from GSF, bt for the Rad I can not see one listed, on searching here the part number quotes does not appear on the GSF website any ideas?
Also do I need to buy anything else other than those two parts?
Are there any othere jobs you would recommend whilst its all in bits?
Thanks
Stu
Offline jamie_pyrite
Re: Heater Matrix and Radiator
« Reply #1 on: 15 March 2010, 11:48 »
Just make sure you buy the £37.80 Heater Matrix and not the cheaper one :)
Maybe worth sticking a new thermostat in while there's no coolant in the system?
Offline drapergti
« Reply #2 on: 15 March 2010, 12:23 »
Will do, managed to get the bits, just need to add.a first aid kit to the list!
Offline Brayster
« Reply #3 on: 15 March 2010, 14:15 »
The new matrix might smoke when u first turn the engine on don't worry like I did if so!!! I'm told it's just the coating added to stop it from rusting in the warehouse... Or u could clean it first?
Offline Reasty
  • Alpine white valver.
« Reply #4 on: 15 March 2010, 17:18 »
My matrix didn't smoke but there was a burning smell for a while so don't worry if you do smell burning as it's just the newness burning off the matrix,I'd also check when the cambelt is due and if it is soon I'd get the waterpump and cambelt done at the sametime,then everything is done and you won't have to drain the system again. just a suggestion tho  :smiley:
Offline Jay
  • balding fat cvnt
« Reply #5 on: 15 March 2010, 17:21 »
Isn't it suggested to wash off the crap in water soapy water before installing the new matrix so it doesn't stink the car out when you use the heater the first time after replacing the matrix? :undecided:
Offline Reasty
« Reply #6 on: 15 March 2010, 18:38 »
Yes.......but i didnt  :tongue:
Offline Ben Lessani
« Reply #7 on: 15 March 2010, 18:54 »
Never noticed a smell in mine :undecided:
Offline Jay
  • balding fat cvnt
« Reply #8 on: 15 March 2010, 20:24 »
I've never had to do one (yet) but read a lot of people complaining about the smell afterwards  :grin:  :lipsrsealed:
« Reply #9 on: 16 March 2010, 10:21 »
not just a smell on mine, loads of grey smoke out the vents. took ages to burn off!
gsf dont appear to do a 16v rad, an 8v one will fit but its longer so you need the top & bottom hoses, plus the rad fan shroud.
