Author Topic: Dom069 - My 8v Story So Far - Deposit Taken :(  (Read 552958 times)
Re: Dom069 - My Mk3 Story So Far, Spacers!!!
« Reply #540 on: 14 January 2011, 19:48 »
Will look great fitted
Offline dom
  • Back in a Mk4
« Reply #541 on: 15 January 2011, 13:57 »
Ok, so after a lot of swearing, shouting and grazed knuckles here is the result:
It's not perfectly straight but it's good enough! It's surprisingly quiet, really not much louder than my standard system so i'm thinking a custom pipe to remove the middle box might be in order!
Offline dazzawest1987
Re: Dom069 - My 8v Story So Far - Magnex Time :)
« Reply #542 on: 15 January 2011, 14:16 »
I thought that when I fitted my back box, didn't make it much louder, so fitted a decat still not much louder so contemplating getting rid of the middle box. Looks smart though mate. Money well spent?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #543 on: 15 January 2011, 14:21 »
Need to remove that centre box mate, i had same issue, should hear mine now, not chav but sounds great  :evil:
here is how my magnex sits
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline dom
  • Back in a Mk4
« Reply #544 on: 15 January 2011, 14:31 »
Definitely money well spent  :cool:
Yeah i'll probably remove the centre box sometime before the summer! Yours sits better than mine, I may have to get it up on some ramps to adjust it as i've now got a heatshield rattle as well  :rolleyes:
I'm sure as hell not spending any more time wriggling around underneath it, I think i've developed claustrophobia  :grin:
Offline F17BAD
« Reply #545 on: 15 January 2011, 14:36 »
i removed the headshield from the back box area and also removed the front (closest the bumper) hanger and rewelded it back in a better spot
did you use the magnex fitting kit ?  i didnt bother
not easy getting exhausts to sit right on the mk3, took me ages to get mine right
Offline dom
  • Back in a Mk4
« Reply #546 on: 15 January 2011, 14:45 »
I only have 2 heatshields, the one around the manifold/downpipe (which is clamped down with jubilee clips) and one over the pipe between the cat and middle box (this one is rattling), you reckon it's worth just ripping it off or should I screw it back on?
I didn't use the magnex kit, just new hangers and sleeves from VW. It went on a treat  :smiley:
Offline F17BAD
« Reply #547 on: 15 January 2011, 14:52 »
ahh, the middle one should extend right back over the back box, i ripped mine off the backbox ares and cut it from the rest of the shield, i know the bit u mean as mine was touching my bit of section of pipe, i had to use tie wraps to secure it - didnt work and neither did new genuine clips
Here is what to do - Exhause heat wrap round the part of pipe thats touching - pack it tight = no rattling  :cool:
« Reply #548 on: 15 January 2011, 19:20 »
Looking good Dom :afro:
Offline dom
  • Back in a Mk4
« Reply #549 on: 15 January 2011, 23:23 »
Cheers Wayne  :cool:
However, I went out earlier and it is knocking quite a lot around the middle silencer, possibly on a torsion bar? Also sounds as if it's rattling on something other than a heatshield as well  :angry:
Means i'm going to have to get it up on some ramps to look at early next week, there's no way i'm doing it with trolley jacks/axle stands again!
