Author Topic: Indicator lever/stalk .... contd.  (Read 809 times)
Offline Maltman
« on: 09 March 2010, 13:08 »
 Re: Indicator stalk/lever..continued
« Reply #6 on: Today at 09:00 »
Thanks again to all who took the time to reply to original query....will put it down to a 'mistake' on my part
The reason I want to fit another lever is because the one on the car operates perfectly well when turning left - and self cancels when the wheel is straightened up.... however..
when turning right, the flashers work fine but the lever fails to self cancel and has to be pulled back manually.... not critical, but annoying ....
Is the fault in the lever unit itself, or has something failed within the steering column/wheel??
Thankyou.
Offline twistedblack69
  • Proud mk2 user and abuser
Re: Indicator lever/stalk .... contd.
« Reply #1 on: 09 March 2010, 13:38 »
It's more than likely just the lever. Mine doesn't self cancel sometimes and I have been told to change the stalks. All the best with the resolution
