Author Topic: Painting engine bay plastics?  (Read 2812 times)
Offline Jimp
« on: 08 March 2010, 17:44 »
Been restoring the plastics in my engine bay. Used some back-to-black spray on my belt cover and it worked fine. My airbox however still looks awful and grey. It was seriously caked in dirt. I got it spotless again and sanded away imperfections and everything but the back to black spray is having little to no effect. Is it safe to use a normal plastic primer + satin black spray paint on the outside of the air box or would I need something specific?
Not low enough mk5
Not on the road enough mk3
Offline Jimp
Re: Painting engine bay plastics?
« Reply #1 on: 14 March 2010, 12:32 »
Anyone?
Not low enough mk5
Offline radz
« Reply #2 on: 15 March 2010, 11:57 »
Pretty sure I have seen a few posts/threads on painting the engine bay, have you had a search?
I can't right now as my iPhone is being a turd
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #3 on: 16 March 2010, 11:59 »
should be okay tbh i have my lower engine cover,battery cover and air box upper cover all painted in this method and they are fine  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Jimp
« Reply #4 on: 16 March 2010, 20:46 »
Great, thanks for the info  :smiley:
Not low enough mk5
Offline flash-derby
« Reply #5 on: 17 March 2010, 09:17 »
a mate of mine painted all his fuse covers/air box etc on his astra with no issues.
if its got pistons or tits, either way its gonna be expensive
  • "1.8T AGU"
« Reply #6 on: 17 March 2010, 12:18 »
heres mine done (won't pass up a chance to post a pic  :rolleyes:)
pkv0208
« Reply #7 on: 02 April 2010, 02:19 »
Helloo,
A few years back i colour coded the engine covers on my dads passat i was driving at the time.
I did a quick write up for the ukpassats forum at the time which ive copied below.
hope it helps! (ps, it was my 1st attempt at painting ANYTHING lol)
Orignal Engine Bay
Covers Removed and Wiped Down
Mask
Wet Sand Covers using 600grit Wet and Dry Paper
Primered with Halford Plastic Filler Primer to remove imperfections and and scratches
Sand again using 600g Wet and Dry
Apply Base Coat (so less paint is needed to cover yellow) Used Halfords Grey Plastic Primer
Sand again using 1200g Wet and Dry
Paint Using Halfords Colour Matched Paint
Then 2 Coats Of Lacquer and.....
(Airbox cover is still inbase coat as ran out of paint!) Its worth the effort and time, do not rush it otherwise will show in the work completed.
Offline snifferdog
« Reply #8 on: 06 April 2010, 18:47 »
That looks spanking!!! Made me wanna do summat about my bay!!
