Author Topic: Help just cleaned throttle body now have a problem  (Read 4167 times)
Offline oliver07
  • golf gti T 200BHP
Re: Help just cleaned throttle body now have a problem
« Reply #10 on: 06 March 2010, 18:42 »
mate all i know is my car had a new starter fitted this week vw disconected the battery my rev counter was all over the place nd the car kept cutting out. I took it back they cleaned out the throttle body out when i asked why they said when you disconect the battery it upsets the settings so as said leave it connected and give the TB a real good clean.
 :grin:
Offline ian007miles
« Reply #11 on: 06 March 2010, 18:45 »
Cheers for all the help ille have a go tomorro and iple update thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline ian007miles
« Reply #12 on: 07 March 2010, 19:26 »
Hi justvto let you all no I took the throttle body off again to day and cleaned it again around the butterfly and even in the little pipe at the top and now it's all ok and runnig fin and the revs are steady. Thanx for all your help
Offline oliver07
  • golf gti T 200BHP
« Reply #13 on: 07 March 2010, 19:29 »
glad to be of help.
 :laugh:
Offline Stronz
  • Sold!
« Reply #14 on: 07 March 2010, 19:31 »
Did mine today. It wasn't as dirty as I expected to be honest.
Probably means my occasional rough idle is down to something else  :lipsrsealed:
Offline Purely VAG
« Reply #15 on: 07 March 2010, 20:55 »
ECU adapts settings over around 25/26miles.
Disconnecting battery just makes it do it straight away fresh.
It doesn't "Cause" problems and no vagcom is required.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #16 on: 07 March 2010, 22:54 »
on my mtor when cold start the revs sit in between 1k-2k till it warms up then settles this normal or is this something to do with my splitter valve being open?
Offline oliver07
  • golf gti T 200BHP
« Reply #17 on: 07 March 2010, 23:09 »
The info I put up was from the local vag garage they said after the battery is disconnected it can cause the settings to default.
Offline jamrox
« Reply #18 on: 07 March 2010, 23:16 »
I cleaned my TB and it seems to run worse, i got right in and cleaned every bit i could but it still isn't normal after 500 miles of driving. It's an agu with cable throttle, idles at 1100rpm when it's warmed up, used to be 800rpm
Offline Purely VAG
« Reply #19 on: 08 March 2010, 10:24 »
No thats exactly what they do...Default and then counter and adapt again rather than taking 26 miles to do it.
