Author Topic: Faulty ISV symptoms  (Read 2511 times)
Offline raks.2008
  • 1992 MK2 16V
Faulty ISV symptoms
« on: 04 March 2010, 20:25 »
I have searched all the ISV threads and no where does it state problems that are related to the ISV. I have a 16V KR and the ISV buzz's when the ignition key is turned, but when the car get warm it regularly cuts out when the revs drop.... Does this mean I have a faulty ISV? I did clean it with petrol as learnt from a thread but didnt work...
Offline raferackstraw
Re: Faulty ISV symptoms
« Reply #1 on: 04 March 2010, 21:32 »
yes isv can cause cut out, give it a clean with carb cleaner there's load of threads on this also overrun cutoff valve can be a cause, aswell as isv control module
do a search for 16v cutting out or 16v idling problems
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Alec
« Reply #2 on: 04 March 2010, 21:35 »
Blue temp sensor might be worth checking aswell
Offline SimonG
« Reply #3 on: 04 March 2010, 22:33 »
Not on a KR.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline Alec
« Reply #4 on: 05 March 2010, 00:49 »
Not on a KR.
If I had read the thread properly I would of known its a valver  :rolleyes:
But saying that dont these pose a problem on valvers aswell?
« Reply #5 on: 05 March 2010, 09:52 »
try unplugging the over-run valve, mine used to cut out due to this. its the black plastic thing behind the airbox
