Author Topic: Temp gauge sender  (Read 1984 times)
Offline Reasty
  • Alpine white valver.
Temp gauge sender
« on: 02 March 2010, 14:09 »
Alright guys and girls could someone please verify for me where the temp gauge sender is on a 94 mk3 8v gti (2e engine code)
thanks very much. :smiley:
Offline leegt5
Re: Temp gauge sender
« Reply #1 on: 02 March 2010, 14:48 »
This is the 2e engine in a passat but the golf will be the same
Its in the top of the black housing the coolant pipe from the radiator is going into. Just to the right of the dipstick.
« Last Edit: 02 March 2010, 14:52 by leegt5 »
Offline Reasty
« Reply #2 on: 02 March 2010, 15:34 »
I thought this was the ecu temp sender?  :huh:
« Reply #3 on: 02 March 2010, 15:54 »
it does both, 4 pin unit.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 02 March 2010, 19:02 »
just make sure you buy the correct colour...
Offline Reasty
« Reply #5 on: 02 March 2010, 19:20 »
What colour should it be,I have just replaced it and the new one was black 4pin is this right
the only reason I ask is I'm having big trouble with the car running at 110 degrees and have replaced everything I can think of now and it still won't run at 90 could it be the temp sender is the wrong one and giving a false Reading on the gauge as the car dosnt overheat it just gets to 110 then sits there even I in traffic.
Offline Carl MK3 GTI 8V
« Reply #6 on: 02 March 2010, 19:34 »
ye the 2E engine needs the black and yellow one with 4 pins!
Offline Reasty
« Reply #7 on: 02 March 2010, 20:42 »
Hmmm its just black this one,it had a yellow cable tie round it when i got it out the packet but overall its just black,i got it from eurocarparts,i think i might get a thermometer and see what temp the water in the xpansion tank is when its running at 110 as this problem is really doing my head in now.
  • Back in a Mk3...
« Reply #8 on: 02 March 2010, 20:49 »
it should have a coloured ring where the connector plugs on....but I'm guessing the cable tie is ecp's version?
Offline Reasty
« Reply #9 on: 02 March 2010, 21:23 »
Yeh it was a coloured ring and it was yellow,so looks like its got the right sender then  :angry:
