Author Topic: Torque setting for camber bolts.. and top nut  (Read 1931 times)
Offline bamberjim
« on: 28 February 2010, 22:50 »
I did a search and could not find the answer so if there is a link could anyone point me in the right direction
I am going to fit my coilovers this week and need to know
Torque setting for the camber bolts and the rear bottom bolt also torque setting for the top... I don't have a the hayne book, also any advice on setting the basic camber for a period while the coilovers settle then i will get it into the garage
Thanks in advance
Jim
Re: Torque setting for camber bolts.. and top nut
« Reply #1 on: 28 February 2010, 23:33 »
I did mine up with a largish bar, top nuts don't need to be mega tight however.
Offline bamberjim
« Reply #2 on: 01 March 2010, 20:31 »
Cheers.. got the backs done, my green rims won't fit as the coilover is wider than the old strut.... so either i have to buy new adapters or put the cups back on.. cups on for now... looks loads better, wil get on with the front tomorrow
« Reply #3 on: 01 March 2010, 20:51 »
Looks better with cups.
Offline christomk3gti
« Reply #4 on: 01 March 2010, 20:57 »
them cups are gorgeous :afro:
Black 8v GTI............. Whats a Waffle Valve?
Offline bamberjim
« Reply #5 on: 01 March 2010, 21:35 »
i think the green rims were a major fail TBH.. going to stick with the cups for a bit if the fronts go on ok.. i do want to drop down to 16's eventully..
« Reply #6 on: 01 March 2010, 21:36 »
Are they Boxster wheels by the way
Offline bamberjim
« Reply #7 on: 01 March 2010, 21:57 »
They are called cup2's, mine are all fronts 17x7 et55 with 15mm adapters ET40, they were fitted to 964's 993's 928's 944's and some boxsters..
« Reply #8 on: 01 March 2010, 21:59 »
the cups are  :cool:
Offline bamberjim
« Reply #9 on: 02 March 2010, 12:22 »
I can't undo the top nuts on the front :angry: :angry:
Will have t drive down to the garage and get them to crack them off...  there should not be a proble driving with coilovers on the back and lowered springs on the front?????  car sitting level.
Green rims are for sale :grin: :grin:
