Author Topic: Hand Polisher help / advice wanted !  (Read 3173 times)
kanemartin101
« on: 28 February 2010, 21:12 »
I am really after a hand polisher! Just want some advice really and don't want and can't really go out and spend much more than £60 was just wondering whats best to go for?! If needed i could get a pannel to practice on before setting loose! Also need direction as to polish etc to use! Thanks
Offline Evoss
Re: Hand Polisher help / advice wanted !
« Reply #1 on: 28 February 2010, 22:09 »
Spit Shine !!!
Jokes  :laugh:
I use Auto Glym polish somthing. I just stick it on a rag and rub it in :) comes out smashing
Offline GOLF_STU
  • THE_GIT
« Reply #2 on: 28 February 2010, 22:31 »
not sure but think he meant along the lines of a machine polisher???  :undecided:
V TEC KICKED IN Y'ALL!!!
Offline Dan J
« Reply #3 on: 28 February 2010, 23:09 »
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=331&idcategory=21
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=365&idcategory=19
i know you stated you've only got around 60 to spend but your not going to get what you want unless you up your budget a little bit im afraid.
Offline Louis
« Reply #4 on: 02 March 2010, 18:00 »
Instead of starting a new thread thought i would add to end of this one, with these polishers what do the different pads do, cutting pad, polishing buffing etc etc, was thinking of getting one soon (dual action) and jsut wanted some guidence on which to get and what order to use them in thanks :)  :cool:
Offline Dan J
« Reply #5 on: 02 March 2010, 19:19 »
the different pads are for different levels of compounds, for heavy/aggressive compounding you have dense quite stiff pads or even wool pads for use with heavy cutting/coarse compounds , the medium density pads are for polishing using finer componds, then you have finishing pads for the final buffing stage which removes marring/swirls etc with finishing compounds and glazes.
the links in my post above are what i think is good for someone just starting out or have minimum experience with a machine, Da's are safe for the begginer and are a good tool to build on your technique/s
hope this helps.
« Last Edit: 02 March 2010, 19:28 by dubplate Dan »
Offline Louis
« Reply #6 on: 03 March 2010, 19:29 »
ahh yeah thats cleared it up abit, so i can still use the same sort of polish i would have used if i was doing it by hand? or do you need a special type ofr a polisher?  also can you apply polish using it or do you apply the polish by hand an then buff with the polisher? sorry for the simple questions lol any help apprciated :)
Offline stealthwolf
« Reply #7 on: 04 March 2010, 09:17 »
You can use polishes with hand but quite often they're more difficult to use by hand since you have to break the polish down. Basically, as you polish, the bits of polish break down further and further. A bit like going from rough sandpaper to supersmooth sandpaper. It's much easier with a machine.
 There's a link on detailingworld in the Guides section. On iPhone so a bit awkward to link. It tells you how to use a polisher. Basically, prep the polishing pad with some quick detailing spray, place four skittle-sized blobs of polish on the pad. Then place the pad on the car and set the polisher at its lowest speed. Then move the machine around to spread the polish over a small area eg 12in by 12in. Then increase the speed in increments and continue to move the polisher, breaking down the polish into ever finer particles.
Offline MDSS MK6
« Reply #8 on: 04 March 2010, 14:11 »
http://www.detailingworld.co.uk/forum/showthread.php?t=63859
Cancelled Order
Mk5 R32 instead.....and change too:)
