Author Topic: Oil Press - Stop Motor ***Turbo Pics Page 4**  (Read 8281 times)
Offline GOLF_STU
  • THE_GIT
Re: Oil Press - Stop Motor
« Reply #10 on: 27 February 2010, 22:44 »
what is strainer, is it oil sump plug? Now tomorrow is sunday so can't get these and must go to uni on monday, i'm stuck now must sort this tomorrow
to be on safer side, not driving car atm
I am left with only option to go to halfrauds to get engine oil  :sad:
unfortunatly it means removing the sump as its the pick up for the oil pump. but please dont drive it untill you definatly know or instead of it costing you £40-£50 it could be £1000+
V TEC KICKED IN Y'ALL!!!
Offline richw911
« Reply #11 on: 27 February 2010, 22:48 »
I know yours wont be like this but there are Some pics here: http://members.cox.net/ambox/audi_sludge/
Offline Devilz
  • Cruisin is not a crime
« Reply #12 on: 27 February 2010, 23:04 »
I will check the oil cap tomorrow in morning, hope its not the problem. touch wood
but what if its all black  :lipsrsealed:
Offline walchy01
« Reply #13 on: 28 February 2010, 11:01 »
I had the same problem last month, STOP light on Oil etc etc.... i was concerned that i had bought a duf one  :sick: Looked all over for the problem, ended up running it into the  main dealers to get it sorted, it was a simple switch/connector that had come loose/off and was showing there was a problem.
As i said i looked all over and couldnt see any loose wires/plugs/connectors etc but i am no expert.
Cost me £48, but it put my mind at rest that i wasn't gunna sieze the engine whilst still driving it. :laugh:
Thanks
Offline Devilz
« Reply #14 on: 28 February 2010, 12:50 »
what can be the possiblilities for oil sump crack, besides hitting road bump which I didn't
Offline Devilz
« Reply #15 on: 28 February 2010, 15:36 »
Is there anyway to check if sump is cracked besides jacking the car???
Offline GOLF_STU
  • THE_GIT
« Reply #16 on: 28 February 2010, 18:05 »
if its cracked you'l have oil dripping
Offline Devilz
« Reply #17 on: 28 February 2010, 18:49 »
I checked oil strip and it was dry  :lipsrsealed:
Didn't started my car since then, hoping no oil cream as I couldn't open oil cap. It was for some reason very tight  :embarassed:
Offline mac456
« Reply #18 on: 28 February 2010, 19:17 »
so your saying there is no oil in your engine?
Offline Devilz
« Reply #19 on: 28 February 2010, 23:25 »
if strip is dry, there is no other reason  :lipsrsealed:
