Author Topic: Oil Press - Stop Motor ***Turbo Pics Page 4**  (Read 8280 times)
Offline Devilz
  • Cruisin is not a crime
« on: 27 February 2010, 17:17 »
I was driving back to home today and all of sudden got warning on Oil Press - Stop Motor, this message disappeared in like 2 seconds. Checked oil level, which is alright, what can be the cause of it  :undecided:
« Last Edit: 03 March 2010, 19:51 by devilz »
Offline T_J_G
Re: Oil Press - Stop Motor
« Reply #1 on: 27 February 2010, 17:19 »
Blocked sump strainer?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 27 February 2010, 17:36 »
either that or the pressure switch is on it's way out
Offline Devilz
« Reply #3 on: 27 February 2010, 19:13 »
is it alright to drive like this even though engine oil is alright
Offline gti_shaun
« Reply #4 on: 27 February 2010, 19:19 »
its difficult to say if its ok to drive it as i cant see or here the engine running, if you had low oil pressure you would have tapping noises as the oil fed tappets would be starved of oil, so if there is non of this i think it would be fine, but you need it checked out ASAP none the less!
Offline Devilz
« Reply #5 on: 27 February 2010, 19:31 »
Car is running abosoultely fine, no noise or anything. Problem is its sunday tomorrow so have to wait till monday to get it checked
Offline richw911
« Reply #6 on: 27 February 2010, 19:57 »
I wouldnt!! Get the strainer checked as said  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 27 February 2010, 20:01 »
buggered if I'd drive it  :huh:
Offline GOLF_STU
  • THE_GIT
« Reply #8 on: 27 February 2010, 20:48 »
definatly.....for the price of the strainer and an oil change it isn't worth it  :smiley:
V TEC KICKED IN Y'ALL!!!
Offline Devilz
« Reply #9 on: 27 February 2010, 22:34 »
what is strainer, is it oil sump plug? Now tomorrow is sunday so can't get these and must go to uni on monday, i'm stuck now must sort this tomorrow
to be on safer side, not driving car atm
I am left with only option to go to halfrauds to get engine oil  :sad:
« Last Edit: 27 February 2010, 22:39 by devilz »
