Author Topic: Wheel Bearing.  (Read 3982 times)
Offline barry-gti
Re: Wheel Bearing.
« Reply #20 on: 25 February 2010, 08:40 »
i dont think you need to do anything to the rear beam. AD Autotechnik rekon about an hours work...
Offline johnson6672
Re: Wheel Bearing.
« Reply #21 on: 25 February 2010, 08:55 »
Bearing done. no press needed, just hammer and brass drift and punch on both inner and outer race.
The 30mm socket is for the hub nut.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline harries
Re: Wheel Bearing.
« Reply #22 on: 25 February 2010, 13:17 »
How much a bearing set you back got to do both on mine making a loud rubbing noise now. any 1 got part numbers? cheers
Offline Steve_PD
Re: Wheel Bearing.
« Reply #23 on: 25 February 2010, 18:19 »
so must have been lucky then not using a press :lipsrsealed:
Offline johnson6672
Re: Wheel Bearing.
« Reply #24 on: 25 February 2010, 18:54 »
Got from here http://www.vwspares.co.uk/g4wheel_drive.php
Offline AudiA8Quattro
Re: Wheel Bearing.
« Reply #25 on: 26 February 2010, 00:05 »
Are mk4's different then?  :tongue:
I've never worked on a mk4, just quoting my experience with other VAG cars.
Have you done any other front bearings except mk4's before?
