Author Topic: Really feel like throwing the car away now!!!!!!! Seriously  (Read 1780 times)
Offline naturn007
Hi all,
As many of you are aware I have posted on here many times before, about my golf gti 8v 96 cutting out and not starting from hot.
I really thought the problem was sorted with the Crankshaft Position Sensor being changed, I have also changed the ignition switch, and coil pack.  The CPS was the last part I changed.
Everything seemed good for a week, and now the problem came back today!!!!!!
I am seriously p*ssed off with it now, when it's running it is lovely.
I plugged it into a V-checker, picture below of the v-checker, before you all cuss it, I know its only a cheep one lol.  It came up with this code 00532 supply Voltage.  Any ideas if this can be linked to the problem, and what parts would I change? Dizzy cap? Leads? Plugs?
Any advice welcome, as I am sorry to say this, I am considering going back to Fords.  I owned Fords for seven years previous to the golf, and not one let me down, EVER!!
Offline Cooper_si
Re: Really feel like throwing the car away now!!!!!!! Seriously
« Reply #1 on: 23 February 2010, 16:27 »
Is the battery and earth ok ?
Owned: 88 Polo GT Highly Modded (FBC), 91 Polo G40 Highly Modded (PPP), 90 Mk2 Golf Driver Modified (LWR)
NOW: 92 Mk3 Golf GTI 8v (KDD) no, i dont like the exhaust either lol
Offline naturn007
« Reply #2 on: 23 February 2010, 16:33 »
The battery is fine, how do I check the earth?
Offline oneblueleg
« Reply #3 on: 23 February 2010, 17:15 »
rather than checking the relays... http://www.golfgtiforum.co.uk/index.php?topic=143254.10 did you actually change them? it's so cheap and easy you may as well, my problems were caused by them... they can be intermittent...
Offline AudiA8Quattro
« Reply #4 on: 23 February 2010, 17:20 »
+1 Change relays if not done already.
Christo77
« Reply #5 on: 23 February 2010, 17:28 »
Still problems eh..
If the relays mentioned previously don't sort it i guess you need to get a decent specialist diagnostic on it and source the problem once and for all..
Probably too far for you but Colin Gunning in Hertford did mine as a freebe while i was there..admittedly it was having other jobs done on it, Decent chap and a VW specialist but independant.
Christo
Offline Paul86S2
« Reply #6 on: 23 February 2010, 22:56 »
This might help.
http://wiki.ross-tech.com/index.php/00532
Check the voltage coming out of your alternator.
Check your battery and other earth points, and check wiring connectors.
Paul
Offline Nino
« Reply #7 on: 24 February 2010, 09:52 »
Hang in there m8 i know how u feel, my car started playing up i fix what i thought it was only to uncover something else, which uncoveed something else... i think you get the idea! but now it runs lovely and i got such a big sence of accivement when it worked :)
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline axewielder
  • 95 dragon 8v
« Reply #8 on: 24 February 2010, 09:54 »
00532 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low Battery or Bad Ground
http://www.golfgtiforum.co.uk/index.php?topic=90910.0
not quite sure wether this is right or causing your problem?
Offline GTIMK3LEE
« Reply #9 on: 24 February 2010, 10:54 »
Only just got my gti Mk3 and the previous owner by the looks had had problems for some time and
chopped it in.
The car was stuttering in every gear around 1500-2000 revs and losing power, he had replaced everything
by the looks to find the problem, dizzy and rota, plugs, leads, the lot, even a new Bosch ecu costing £300,
i only paid £375 for the car and its mint with fsh etc. First thing i did was change the cambelt and found the bottom crank
pulley to be at fault, there is a little key on the pulley that had been damaged in the past and someone had
glued it back on, this had moved and knocked the timing out causing the problem.
Sorry for the long reply but i think its best if you like the car to get it sorted, get it to a specialist and let them
find the problem if you have exhausted everything else.
That is what the previous owner of my car should have done and didn't, now i have a lovely car at his expense.
