Author Topic: What's wrong with my GTI?  (Read 4440 times)
Offline Wheatles
« on: 22 February 2010, 19:07 »
In neutral the car sounds like its on its way to stalling, then revs from 800 to about 2000 revs then back to 800 revs. This revving pattern keeps repeating itself without the car stalling  :undecided:
I put Esso super unleaded 97 petrol 6 days ago because was nowhere near a shell garage to get the proper pertrol, unsure if this is related.
The car still feels responsive when driving although the revs dont seem to drop off as quick when lift foot completely off accelerator
(Manual not DSG)
Any ideas?
« Last Edit: 22 February 2010, 19:11 by Wheatles »
Offline ub7rm
Re: What's wrong with my GTI?
« Reply #1 on: 22 February 2010, 19:33 »
Whats the age and mileage?
MAF is one possible culprit but there are many more.  Best bet is to get it hooked up to a diagnostic machine (VAGCOM or VCDS as its now known) is a good one.  Depending where you are there might be a forum member willing to help out  :smiley:
Any warning lights on?
2020 BMW 128ti
2017 Golf GTD Estate
Offline LAD
« Reply #2 on: 22 February 2010, 19:43 »
Hi,
Had similiar problem in my case it was down to PCV. Search forum idle problem, has photo of part.
Offline Wheatles
« Reply #3 on: 22 February 2010, 19:57 »
Thanks
Its 2005, 48000 miles, no warning lights on dash
live in Leeds.
« Last Edit: 22 February 2010, 20:00 by Wheatles »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #4 on: 22 February 2010, 19:59 »
Its 2005, no warning lights on dash
I would also say a vac leak by the sound of it.
You really need to get a laptop hooked up to the car so you can see what the ecu is seeing and doing.
Where are you from?
Nick
 01455 617233
Offline Wheatles
« Reply #5 on: 22 February 2010, 20:01 »
Leeds
Offline FamilyDub
« Reply #6 on: 23 February 2010, 09:29 »
It could be a number of things related, or unrelated to each other...
I had the high/low idling symptoms for a while, but a new throttle body sorted it out, but it could also be the MAF, PCV, DV, software reflash, fuelling issues...
Search for all of these things on the forum for some more info, but really VAGCOM/VCDS is your friend. Get some data logged and it'll save you time & money. :afro:
Leeds
There's quite a few people on here from in/around the Leeds area. If not in here, deffo in the MKVI section.
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
« Reply #7 on: 23 February 2010, 10:43 »
Have you tried disconnecting the cable going to the MAF?
Offline Hurdy
« Reply #8 on: 23 February 2010, 11:19 »
Also I'd look at the coilpacks too, but by the symptoms you describe it could be simply loose pipework. Have you been under the bonnet recently? if so where and what for?  Often it is something that gets disrupted inadvertantly whilst doing another job. :smiley:
Seat Leon Cupra Black 290 DSG
Offline Wheatles
« Reply #9 on: 23 February 2010, 19:24 »
Thanks for all the replies.
I have only had the car for 4 months so bit gutted that something gone wrong already, warranty expired last month!
Can somebody explain what MAF, PCV, DV are cos i havent got a clue being a newbie!
I havent been under the bonnet, only to check oil etc but will check see if anything looks loose.
What are Stealers likely to charge to investigate the problem?
Cheers again
