Author Topic: Mould in boot any ideas?  (Read 1641 times)
Offline colster
« on: 20 February 2010, 20:14 »
Hi,
My brother has a M reg golf with a nasty odour problem. In the boot and only the boot area there is a lot of mould growing under the carpet and in the spare wheel area.
Has anybody else had this problem or heard of a solution?
Is there an area where water could be getting into the boot area. Everywhere is dry so it is just the boot area.
Many thanks.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Mould in boot any ideas?
« Reply #1 on: 20 February 2010, 20:25 »
Water could be getting in through the rear light apertures. Have you got aftermarket light clusters? as these sometimes have sh!tty gaskets supplied with them.
Offline gazpowells
« Reply #2 on: 21 February 2010, 08:51 »
+1
Offline Reasty
  • Alpine white valver.
« Reply #3 on: 21 February 2010, 08:59 »
+1
+2 also check for holes Behind the numberplate as these panels rust out into holes thus when water runs down the bootlid it gets into the car.
« Reply #4 on: 21 February 2010, 19:00 »
+3 I had the same issue.
Offline dan iow
« Reply #5 on: 21 February 2010, 19:28 »
i had a leaking rear washer jet pipe as it got worn away by opening the boot all the time
Offline jezza16v
« Reply #6 on: 21 February 2010, 19:35 »
+4, have the same issue, after market lights, gaskets leaking. Another job to do!  :rolleyes:
Offline luckycharms
« Reply #7 on: 22 February 2010, 15:10 »
On my previous golf (1.4 CL) I'v had water sneak in through the light seal (standard lights) and boot seal near the light. took both off and tigersealed them. no probs after that!
The washer set up on the GTI seems to be somewhat different and a bit of a mess with several pipes running in and around that direction, all of which are damp to the touch, though no actual water there...
Offline harlemex
« Reply #8 on: 22 February 2010, 20:25 »
had the same issue. used sealant which worked for about 9 months and now its leakin again. Whats tiger seal and is it any good?
