Author Topic: Mould in boot any ideas?  (Read 1642 times)
Offline luckycharms
Re: Mould in boot any ideas?
« Reply #10 on: 23 February 2010, 04:15 »
Quote
Whats tiger seal and is it any good?
Its very good. Though come to think of it i used 'tec 7' , another brand  for that job.:smiley: same thing Any sealant should do really.
I took off the boot seal and ran the tiger/tec 7  into it just to make sure as there was some corrosion where the two metal panels meet along the boot lip.
Offline dom
  • Back in a Mk4
« Reply #11 on: 23 February 2010, 09:10 »
i had the same problem when I had my 1.4. I put in rear lights from a gti and the foam seal that goes between the light cluster and car body was split. Changed the seal, mopped up the water and the problem was solved.
Offline Sonic2
« Reply #12 on: 24 February 2010, 09:15 »
Hi,
My brother has a M reg golf with a nasty odour problem. In the boot and only the boot area there is a lot of mould growing under the carpet and in the spare wheel area.
Has anybody else had this problem or heard of a solution?
Is there an area where water could be getting into the boot area. Everywhere is dry so it is just the boot area.
Many thanks.
1) clean the area throughly, wait for the issue to come back- it might help you trace where it's coming from.
2) has it always been there, or something thats surfaced recently? (as suggested, changing rear lights may have let water get in)
3) if there are any plugs in the bottom of the spare wheel area, check them for any leakage.
good luck! :)
