Author Topic: Max wheel size on 40mm lowered MK3?  (Read 6021 times)
Offline buzzkip
« on: 15 February 2010, 14:19 »
Hii all,
I was wondering whether or not my wheel arches would experience some rubbing if I stuck on some 17" BBS RS Split Rims on a 40mm lowered MK3.
Could anyone guide me on wheel size and lowering max?
Thank you,
Changed username from "iAMarshall".
Offline Deano2711
  • 1992 VR6
Re: Max wheel size on 40mm lowered MK3?
« Reply #1 on: 15 February 2010, 14:42 »
Hi Mate     17 inch rims will be fine Mate.  The pic in my sig is mine lowered 40mm rear and 60mm front with 17 inch wheels on and I get no rubbing. Others on here have lowered a lot more and have no trouble. 40mm drop will give you no problems Mate.     Cheers      Deano
Offline buzzkip
« Reply #2 on: 15 February 2010, 14:47 »
Awesome thanks!
Offline buzzkip
« Reply #3 on: 15 February 2010, 16:39 »
how about 18"?  :smiley:
Offline shepgti
« Reply #4 on: 15 February 2010, 16:43 »
get 19's (it will look proper bling :cool:)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 15 February 2010, 16:48 »
Make it 20" and raise the car by 40mm?   :laugh:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #6 on: 15 February 2010, 19:32 »
16"s is the better all round choice and will give you loads of room in the arches, 17"s will fit but may rub the rear arches.
Offline Deano2711
  • 1992 VR6
« Reply #7 on: 15 February 2010, 20:08 »
I have 17's fitted on mine and they do not rub (touch wood) but I think they are not right for the car and have done a deal for some 16 inch wheels and can't wait to fit these and get some new pictures took at the weekend.
Offline tomsdubs
« Reply #8 on: 18 February 2010, 18:52 »
im down 35mm and my 17's only rub when a fatty gets in the back
Offline christomk3gti
« Reply #9 on: 18 February 2010, 19:11 »
Easy fix.
Dont allow fatties in. :afro:
Black 8v GTI............. Whats a Waffle Valve?
