Golf mk3
hardmonkeys
Max wheel size on 40mm lowered MK3?
Topic: Max wheel size on 40mm lowered MK3? (Read 6022 times)
buzzkip
GTI forum regular
15 February 2010, 14:19 »
Hii all,
I was wondering whether or not my wheel arches would experience some rubbing if I stuck on some 17" BBS RS Split Rims on a 40mm lowered MK3.
Could anyone guide me on wheel size and lowering max?
Thank you,
Changed username from "iAMarshall".
Deano2711
1992 VR6
Re: Max wheel size on 40mm lowered MK3?
15 February 2010, 14:42 »
Hi Mate 17 inch rims will be fine Mate. The pic in my sig is mine lowered 40mm rear and 60mm front with 17 inch wheels on and I get no rubbing. Others on here have lowered a lot more and have no trouble. 40mm drop will give you no problems Mate. Cheers Deano
buzzkip
GTI forum regular
15 February 2010, 14:47 »
Awesome thanks!
buzzkip
GTI forum regular
15 February 2010, 16:39 »
how about 18"?
shepgti
15 February 2010, 16:43 »
Quote from: iAMarshall on 15 February 2010, 16:39
how about 18"?
get 19's (it will look proper bling
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
15 February 2010, 16:48 »
Make it 20" and raise the car by 40mm?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Wayne
Sir Postalot
Reply #6 on:
15 February 2010, 19:32 »
16"s is the better all round choice and will give you loads of room in the arches, 17"s will fit but may rub the rear arches.
Deano2711
1992 VR6
Reply #7 on:
15 February 2010, 20:08 »
I have 17's fitted on mine and they do not rub (touch wood) but I think they are not right for the car and have done a deal for some 16 inch wheels and can't wait to fit these and get some new pictures took at the weekend.
tomsdubs
Reply #8 on:
18 February 2010, 18:52 »
im down 35mm and my 17's only rub when a fatty gets in the back
christomk3gti
Reply #9 on:
18 February 2010, 19:11 »
Easy fix.
Dont allow fatties in.
Black 8v GTI............. Whats a Waffle Valve?
Golf mk3
hardmonkeys
