Author Topic: Car Hinge  (Read 5167 times)
Offline VWKev
  • Please Support Non-Human Rights
Car Hinge
« on: 15 February 2010, 12:56 »
How are you guys cleaning this ? I've tried a little tooth brush, but it just smudges little bits of dirt around and you cant get them completely off. I cant blast the dirt away as the door and inside of the car will get soaked.
Any ideas ?
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline Guy
Re: Car Hinge
« Reply #1 on: 15 February 2010, 13:05 »
Any ideas ?
door shuts - spray with APC and work in with a brush and then use a blade nozzle on a pressure washer - start the nozzle 'off' the car and then gently work it onto the bodywork/door shut
I tend to not do into the actual hinges too much as the grease is there for a purpose
Offline VWKev
Re: Car Hinge
« Reply #2 on: 15 February 2010, 13:14 »
Any ideas ?
Thanks for that.
I didnt explain myself properly. I can see the grease around the hinge so I dont touch them. I'm more meaning like down the bottom of the doorwhere the fold meets the sill, right in that corner bit I cant get into. Then going right up the inside part of the 'hinge' (where the inside of the door meets the car itself) I can only get to certain areas. Sorry I just call that the hinge part.  :grin:
Offline Guy
Re: Car Hinge
« Reply #3 on: 15 February 2010, 13:17 »
Any ideas ?
Thanks for that.
look up there... in bold  :wink:
Offline VWKev
Re: Car Hinge
« Reply #4 on: 15 February 2010, 13:21 »
Cheers will give it a bash.
Offline Guy
Re: Car Hinge
« Reply #5 on: 15 February 2010, 13:26 »
honestly... takes about a minute each shut and you end up with good results
I tend to finish off with a product called autosmart 'finish' which brightens up the area and the plastics nicely  :wink:
Offline VWKev
Re: Car Hinge
« Reply #6 on: 15 February 2010, 13:35 »
When you say the door is shut, and you gently work the 'blade' nossle into the bodywork/seam, no water gets through to the inside of the car ? I would be scared that with the force of the karcher the water would find a way through ?
p.s. that pic looks lovely and clean.
Offline Guy
Re: Car Hinge
« Reply #7 on: 15 February 2010, 14:00 »
No, no.. Door shuts are what the area is called
You have to clean it with the door open otherwise you can't get to it? :huh:
Wrt water getting into the car.. Use the method I suggested with a blade jet from a pressure washer, start it off the car and work onto the area.. If you are really worried then cover your seats etc..
Offline VWKev
Re: Car Hinge
« Reply #8 on: 15 February 2010, 14:02 »
Ahh  :grin:
I totally get you now. I thought that it would push the dirt in towards the car making it easier to wipe away, Sorry.  :embarassed:
Offline Guy
Re: Car Hinge
« Reply #9 on: 15 February 2010, 14:12 »
If you are REALLY worried about water indirectly splashing into the car then you could always spray in the APC, work in well with a brush (long handled radiator brush with the metal taped over works a treat).. And then use a watering can to wash off.. This was my old method and it worked ok :)
