Author Topic: Can there be smoke without fire????  (Read 1868 times)
Offline Brayster
« on: 14 February 2010, 19:19 »
I drove my mk2 for only the second time ever today and for the brief 5 mins it was fun- however the car filled up with smoke after about 5 min- not burning wire smoke it was weird.
But I have just replaced the heater matrix and this was it's first run - had the heater on to check it worked - could this be the culprit?
I checked under the bonnet no smoke there only a leaking flange now the water is flowing round the system.. Do new matrixs' give off smoke for a bit?
Im hoping i haven't short circuited something when I had the dash out.
Offline Reasty
  • Alpine white valver.
Re: Can there be smoke without fire????
« Reply #1 on: 14 February 2010, 19:26 »
That dosnt sound right at all,new matrix's do smell for abit but defiantly don't smoke,could you see where it was coming from?
Offline Brayster
« Reply #2 on: 14 February 2010, 19:35 »
Not really more of a gradual build
up wasn't pouring from the vents but defo coming from there - but did seem to tale off though - might take it out Tom and see-
Offline Alec
« Reply #3 on: 14 February 2010, 19:51 »
If you had oily hands and left grubbyprints all over it I suppose it could smoke if it got mega hot, but I doubt it lol
Thats proper random lol
Offline Brayster
« Reply #4 on: 15 February 2010, 07:54 »
Pretty sure the hands were clean - but u never know what was on it already .... having bought the car with broken bypass valves I have no way of knowing how long it is since anything has flowed through the system. We'll see next time I
take it out I suppose ......
which sadly won't be till the weekend ..
« Reply #5 on: 15 February 2010, 09:48 »
did you clean the matrix before you fitted it? if not, thats why! learnt this myself the hard way, the matrix is coated with a oil/varnish type thing to prevent corrosion when in storage. this takes ages to burn off and it reeks!
Offline Brayster
« Reply #6 on: 15 February 2010, 12:32 »
Err nope slapped it straight in - I thought it must be something like that ... thanks bit of peace of mind if it happened to someone else too ta
Offline jamie_pyrite
« Reply #7 on: 15 February 2010, 14:18 »
Phew!! Thanks for mentioning this RJ. I've got mine to put in shortly :D
Might be worth adding this bit of information to the guide?
Offline Alec
« Reply #8 on: 15 February 2010, 14:50 »
RJ to the rescue!
Offline Brayster
« Reply #9 on: 15 February 2010, 18:50 »
Yep thanks agian rj - Looking back now it funny but at the time I was pretty distressed ..
« Last Edit: 15 February 2010, 18:52 by Brayster »
