Author Topic: Cutting out  (Read 1989 times)
Offline ian007miles
Cutting out
« on: 14 February 2010, 17:51 »
I was driving around this morning and I had the sterio on quite loud and all of a sudden the sub cut out and then I turned the sterio down and it came back on my mids and tweeters are on a different amp but they didn't cut out does any one no what this could be
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline tommk3cab
Re: Cutting out
« Reply #1 on: 14 February 2010, 18:32 »
could be loads of things. a short on the sub amp outputs? a fault in the sub amp? voltage drop causing the sub amp to turn off ( although the last one is the most unlikely.)
the only way to tell is either change for a known working amp and see what happens. It may also be worth inspecting the sub amp and make sure there are no stray cable strands, also worth inspecting the wiring to the sub to make sure they are not damaged.
Offline ian007miles
Re: Cutting out
« Reply #2 on: 14 February 2010, 19:19 »
The amp was in my last car and I was running 2 15" alpine subs and it never don't it then now i'm only running 1 12" kenwood sub and the sub is brand new and I've checked all the wires and apart from the earth being a bit long but not no longer that 15" long I no it should realy be shorter than that but were the amp is it's as short as it can be so I think it might be a voltage drop, how can I prevent this from happaning?
Offline tommk3cab
Re: Cutting out
« Reply #3 on: 15 February 2010, 13:32 »
The earth will be fine as long as it is thick enough, in some cases good results can be achieved by running an earth all the way back to your main battery up front. In other cases this is necessary for good operation.
What I am saying is, don't worry too much about length, as long as it is thick enough and a good contact.
You may not have a good earth, especially ( but not only) if it has been moved recently, it would be worth checking/rechecking you have a good earth.
To check the cables you would pretty much need to go over them with a magnifying glass as even a single strand of cable can cause problems but remain unseen. The ends of the cables are common troublespots.
Other than that...
to test voltage drop you would need some kind of voltmeter/multimeter, connected as close to the amps as possible. If volts are shown dropping under use of the system to much below 12v then the amps may be switching themselves off, if not then volt drop is unlikely the cause.
