Author Topic: remapped cars  (Read 2356 times)
Offline PishY
remapped cars
« on: 11 February 2010, 22:03 »
yo guys!
the previous owner before my had the car remapped by Rtech, now ive just filled the tank with Vpower, and noticed the engine moves a hell of alot more, and the exhaust seems to be popping?
the cars a AGU engine, with the Ko3 turbo :)
so im just wondering, when the car gets remapped, does it get mapped to what fuel it uses? the owner specifys which fuel he uses, the normal or high grade stuff?
cheers
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: remapped cars
« Reply #1 on: 11 February 2010, 22:10 »
Only if it was a custom map plotted out on the dyno, otherwise the ecu will just adjust itself on a generic spec 1 map.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline PishY
Re: remapped cars
« Reply #2 on: 11 February 2010, 22:15 »
ah got ya mate,
the performance is still spot on! was using normal petrol before, but thought id give the vpower a blast, always used that in the past in my Scooby, Focus RS etc :)
but when normal fuel is used, it doesnt move alot, and hardly pops, ill see how it goes. ive got to change the bushes in the dog/bone mount, as myne are shagged completely!
ooo just been browsing the maintenance section, and ive got the symptons of a faulty Temp sensor, so ordered one, and will change that!
cheers
« Last Edit: 11 February 2010, 22:21 by PishY »
Offline northeast_gti-t
  • "1.8T AGU"
Re: remapped cars
« Reply #3 on: 12 February 2010, 20:51 »
nick mentioned to me that it would run better on v-power so for the last 3 weeks i have been using it and intend to use it all the time mine seems to love it and i'm getting a slightly better mpg  :smiley:
2000 Mkiv GTi 1.8T AGU
Offline gtibarnesy
Re: remapped cars
« Reply #4 on: 12 February 2010, 20:57 »
just a quick note to say if you've got a temp gauge fault it's more likely to be the thermostat.  Changed mine today and now the gauge is working spot on.
Offline mikemk4gti
Re: remapped cars
« Reply #5 on: 12 February 2010, 21:11 »
I changed my thermostat yesterday, gauge goes straight to 90 now like it should. Old thermostat looked fine and opened and closed when I tried it but gauge never got far of the bottom so must of been faulty.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Stronz
  • Sold!
Re: remapped cars
« Reply #6 on: 12 February 2010, 22:12 »
Changed my temp sensor last week, but not made any difference, so need to do my thermostat next. Think I will try and hold on until I get my brakes done in the next month or so.
Offline PishY
Re: remapped cars
« Reply #7 on: 12 February 2010, 23:55 »
Yer the temp sender made no difference, the needle drops off when driving so think the thermostat is next :)
Offline TJJONESVDUB
  • Give me lip and il tattoo daihatsu to your head!
Re: remapped cars
« Reply #8 on: 13 February 2010, 00:01 »
well i replaced my temp sender after failing to be able to fit my thermostat and its solved everything..dont buy a cheap one and btw they are now £31 from the stealers for the temp sender  :sick:
Offline PishY
Re: remapped cars
« Reply #9 on: 13 February 2010, 16:32 »
yer ive replaced my temp sender with a genuine VW part, and it still drops off when driving,
thermostat is next, thats never been changed since the car was new, so worth it considering the price they are!
What collant you guys recommend? anyone in particular?
cheers
