Author Topic: Bilberry & Megs  (Read 3470 times)
Offline FOREST GREEN
Bilberry & Megs
« on: 11 February 2010, 16:23 »
Afternoon, just a quick couple of questions please..........
I'm going to do my 1st proper cleaning of my car this weekend, I've got everything that people have suggested (cheers Waxamomo), but when it comes to the alloys, I'm a bit unsure how to use the products...  :undecided:
I have some Bilberry wheel cleaner & Megs tyre gel  :tongue:
Megs tyre gel is pretty self explanitary, but how do you use the Bilberry? and when is the best time to do the tyre gel?
any hints tips would really be appreciated
Cheers for now
Offline Guy
Re: Bilberry & Megs
« Reply #1 on: 11 February 2010, 17:18 »
bilberry... mix to the correct dilution ratio and pop the mixture into a trigger spray or a pressure sprayer
spray on covering the entire alloy and let dwell for a minute (do not allow the product to dry)
work the product into the wheel using your wheel brush of choice... in may case it is vikan brushes
rinse the solution off using a pressure washer or a hose
dry with a waffle or microfibre
i usually apply tyre gel type products at the very very end of the wash cycle... it saves being washed off etc when you are cleaning bodywork etc
Offline jaydubveedub
Re: Bilberry & Megs
« Reply #2 on: 12 February 2010, 14:47 »
Do you have the Megs foam applicator pad?
Saves a lot of mess when applying the tyre shine gel. I would definately recommend getting one if you haven't already.
Waxamomo do them, about £5 i think.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline simonpolly
Re: Bilberry & Megs
« Reply #3 on: 12 February 2010, 17:02 »
You can buy the washing up sponges with one side sponge and the other a rough pad,thease are ideal for putting on tyre gel, you can get a pack of 6 for less than a quid. :wink:
Golfgti build quality is average at best.
Offline Guy
Re: Bilberry & Megs
« Reply #4 on: 12 February 2010, 23:53 »
i use tyre applicators... they are very good for putting stuff on tyres
Offline simonpolly
Re: Bilberry & Megs
« Reply #5 on: 13 February 2010, 15:14 »
Yes and probably 10 times more expensive :rolleyes: :lipsrsealed:
Offline Guy
Re: Bilberry & Megs
« Reply #6 on: 13 February 2010, 18:06 »
not for meeee  :tongue:
Offline VWKev
  • Please Support Non-Human Rights
Re: Bilberry & Megs
« Reply #7 on: 15 February 2010, 18:37 »
I use the megs applicator, its a great wee tool. Only tip I can give with it is that you may think that there is not much in the sponge/applicator itself, but that little thing sooks up a lot of gel. So while you may think you need to use a bit more, give the applicator a good bit of elbow grease and you will see there's still plenty in it.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline stealthwolf
Re: Bilberry & Megs
« Reply #8 on: 20 February 2010, 18:40 »
As guy as said for Bilberry.
I also have a tyre gel applicator, which I love, and I apply the gel last.
Offline northeast_gti-t
  • "1.8T AGU"
Re: Bilberry & Megs
« Reply #9 on: 20 February 2010, 23:55 »
i use the bilberry and find it really good as well as megs tyre gel
the applicator is a decent product but atm i don't use the gel with all the fecking salt it would be off in no time roll on the decent weather to get the tyres looking tidy  :laugh:
2000 Mkiv GTi 1.8T AGU
