Author Topic: Clutch just done...non starter  (Read 8922 times)
Offline morgan100
« on: 10 February 2010, 00:43 »
Im really at the end of my tether with the golf now, its a 2.0 16v GTI, the clutch went on it over two weeks ago so I replaced that, while doing that I noticed a driveshaft was in bits so did that too, stuck it all back together and now it wont start! The battery has run flat so ive been trying to start it by jumping it from my mr2. Ive checked all the connections that I removed while doing the clutch and there all fine. When I turn the key theres a click from the starter as if its trying to engage but no cranking! I replaced the starter motor today with a brand new one and its exactly the same thing. Im really losing patience with it all now...someone please suggest what else i should be checking....
Any help appreciated
thanks
Offline bored_Welsh_lad
Re: Clutch just done...non starter
« Reply #1 on: 10 February 2010, 07:48 »
what about trying to bump it.. might be better than trying to jump it?? just a thought like...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline morgan100
« Reply #2 on: 10 February 2010, 12:16 »
i probably should have mentioned that I tried bumping it the other day and it bumped no problem and sits and runs fine once its bumped. its just once i turn it off again i cant get it started  :cry:
Offline Guy
« Reply #3 on: 10 February 2010, 14:01 »
what about the coil... they can just 'go' for no reason
Offline morgan100
« Reply #4 on: 10 February 2010, 14:32 »
maybe a stupid question but would be engine still not crank if the coil was gone? would it not turn over but not fire up?
I checked the main lead onto the dizzy cap against the body of the car and im not getting a spark, recon thats the problem?? again should the starter still not be turning over the crank though??
Offline morgan100
« Reply #5 on: 11 February 2010, 22:06 »
I checked the coil again and it turns out i am getting a spark so im completely lost now!
I noticed the power wire that goes on the end of the starter had two splits in the insulation and the wire was black underneath so i cut that back until the wire was good again and replaced it with a new wire. but still the same problem...
Someone please help and suggest what i should be checking...im really close to setting it on fire and walking away  :sad:
Offline Nino
  • Insta - F6UGA
« Reply #6 on: 11 February 2010, 22:33 »
Kind of a really stupid reply but you said that your battery has run flat but it bumps fine yea? my GF clio was doing the exact same thing, how ever hers was down to 2 things a flat battery & the starter motor, try a new battery? or does your car have an immobiliser that could be stopping this?
Hope this helps.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline morgan100
« Reply #7 on: 11 February 2010, 22:57 »
Yeah it bumps fine. I just tried my battery from my mr2 in it and the same things happening and that battery is only a few months old  :cry:
The car does have an aftermarket alarm and immobiliser but the it goes off as it should when i press the immobiliser fob in to the slot  :huh:
im losing the plot with this now...new clutch, brakes, tyres....I just want to drive the thing now!
Offline Deano2711
  • 1992 VR6
« Reply #8 on: 11 February 2010, 22:59 »
Might seem a little daft but have you checked/cleaned the earth cable to the starter??
Offline Nino
  • Insta - F6UGA
« Reply #9 on: 11 February 2010, 23:02 »
Dam beleave me fella i really am feeling your pain, check my topic under yours you will see that im in your pain to mate, the only other thing i could sugesst is theres is something somewhere clearly stopping your car from turning over, and if it isnt your starter motor, battery then is must be something cutting the power before it gets chance to do its job by telling the starter motor to get off its fat arse and start :(
