Author Topic: Clutch just done...non starter  (Read 8921 times)
Offline morgan100
Re: Clutch just done...non starter
« Reply #10 on: 11 February 2010, 23:47 »
Im gona take off all the earth connections etc tommorow and test them and clean them again...
honestly at breaking point with it
Offline Deano2711
  • 1992 VR6
« Reply #11 on: 11 February 2010, 23:51 »
You usually find that after you've spent sh!t loads of money it's something stupid like a dodgy earth. Keep the faith Mate will be worth it in the end. Let me know how you get on.     Cheers      Deano
Offline morgan100
« Reply #12 on: 12 February 2010, 00:10 »
tell me about it, it'll be something stupid, i already get the feeling that i didnt need a new starter at all so theres £100 gone already  :cry:
this thing will be running if its the last thing i do!!!
Offline morgan100
« Reply #13 on: 13 February 2010, 14:07 »
Right...probably the stupidest thing ive ever done...i had the wire from the starter to the alternator bolted on but when i was doing the clutch id tucked the wire from the battery to the starter behind the washer bottle  :embarassed: silly boy, so ive connected that back up and the engine is turning over again
but.....it wont start  :angry:
Ive just replaced the coil pack, dizzy cap, rotor arm, plug leads and spark plugs and it still will not start
it sounds like its going to start but it just wont fire  :angry: what should i be checking now?? im getting fed up throwing money at this car
someone help please
Offline javalin
« Reply #14 on: 02 March 2010, 19:53 »
Good that you've got it cranking.  Now...
(1)  Is it sparking?  Check that the cam sensor is plugged in. (on the dizzy)
(2)  Does the fuel pump prime when you turn the key to the "run" position?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
