Author Topic: chug chug chug gt tdi in the morning  (Read 2821 times)
Offline suzyGTI
« on: 08 February 2010, 19:29 »
seems like a few of us are having problems at the mo with shuddering and chugging, maybe its the weather.  what do you think is up with mine??
when the engine is cold (first drive of the day cold.....could be 7am or 2pm stil the same......), sometimes i drive for a couple of minutes and it starts to shudder like its not firing on all cylinders and the ASR light comes on (triangle thingy with a circle - yellow one).  i have to turn the igition off and start it up again, sometimes it will be fine after that, other times it does it another 3 or 4 times but as soon as the engine gets up to tempreture, its fine!!!
Free image hosting by http://www.holdthatpic.com/
Offline asif
Re: chug chug chug gt tdi in the morning
« Reply #1 on: 09 February 2010, 10:52 »
This thread below may help you, sounds like the same problem
http://www.golfgtiforum.co.uk/index.php?topic=143381.0
Best advice I would give is see if someone local to you can scan it with Vagcom to check for faults on there as it will give you a good pointer.
MK7 GT Bluemotion Tech TDi 150
Offline suzyGTI
« Reply #2 on: 13 March 2010, 12:23 »
well carwent in and its the wiring loom problem.  does anyone know the part number or a diagram of exacty where it is?  i can get the loom direct from manufactures so no need to go to the stealer dealer lol
Offline Jay
  • balding fat cvnt
« Reply #3 on: 13 March 2010, 20:47 »
I presume they mean the injector loom?
