Author Topic: sub and amp  (Read 2088 times)
Offline mcgee9t2
sub and amp
« on: 30 January 2010, 11:04 »
ok found a nice 15" fli sub (i know theres better out there but for £30 cant go wrong)
thing is, i dont really have much experience in audio ect. so..
in the spec it says
"RMS power       400 watts
Peak power      1200 watts "
does this mean that it can be powerd by a amp with  a 400 watt output to a 1200 watt output and anywere in the middle?
and also does anyone know a good amp that i can use? i was thinking this but wasnt sure if it would work.
any help apreciated
cheers
Offline tommk3cab
Re: sub and amp
« Reply #1 on: 31 January 2010, 12:01 »
It means you want at least 400 w RMS. You could power it with a 10000w amp if you want as long as you realise it is not a 10000 w sub, this is a mistake many people make for one reason and another.
Offline DanoGTI
Re: sub and amp
« Reply #2 on: 01 February 2010, 19:51 »
I would always (if possible) over-spec the amp. Drive the amp comfortably rather than overload it. You'll get a better sound as the amp will be running efficiently.
Bear in mind that even 400 watts will be SILLY in a car  :grin: Especially with a 15". Lots of sub rather than defined bass. If that's the sound you're after, go for it  :smiley:
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline tommk3cab
Re: sub and amp
« Reply #3 on: 02 February 2010, 13:29 »
Dan
900 is sillier ;) lots of defined bass here though, perfectly matched ;). Come and have a listen if you fancy a drive over the other side of the malverns :)
