Author Topic: MKV GTI - which top-up oil?  (Read 4560 times)
Offline simonkit
« on: 28 January 2010, 13:09 »
 Which top-up oil should I use ?
 thanks
 simon
Offline ifti
Re: MKV GTI - which top-up oil?
« Reply #1 on: 28 January 2010, 14:24 »
Castrol Edge 5w30
Offline Stitch
« Reply #2 on: 02 February 2010, 19:14 »
I'm on long life intervals and use Mobil 1
Offline jaydubveedub
« Reply #3 on: 02 February 2010, 20:27 »
Apparently Mobil 1 is not approved by VW for use in the 2.0 TFSI engine.
Castrol Edge 5W/30 is what you want.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline Stitch
« Reply #4 on: 02 February 2010, 20:31 »
Well it's what the VW dealer has put in my car fro the last two services and it's what they are selling in their parts dept. It's the Mobil ESP 5w 30 and it does have the requited VW code so I'm not sure where you get that info from.
Offline ub7rm
« Reply #5 on: 02 February 2010, 20:39 »
Mobil 1 didn't used to be VW approved but the ESP oil your stealer is using is fully approved by VW.  But only the 5w/30 ESP one, none of the other Mobil oils are VW approved.
« Last Edit: 02 February 2010, 20:48 by ub7rm »
2020 BMW 128ti
2017 Golf GTD Estate
« Reply #6 on: 02 February 2010, 20:45 »
My mistake, apologies.
Didn't realise that they now had one that's approved by VW.
I'll get my coat............. [goes off to swat up on oils]
Offline Stitch
« Reply #7 on: 02 February 2010, 20:46 »
I'll check with VW but that can't be correct or someone needs to tell the Cardiff and Bridgend VW dealers then as the top up oil i've bought from them is the 5W 30 ESP Mobil 1 which they also filled my car with on the long life intervals (I find it odd that both independant dealers would get that wrong (they are now under the same name after Cardiff VW went under but at the time of my services they were indpendant of each other).
Mobil 1 didn't used to be VW approved but the ESP oil your stealer is using is fully approved by VW.  But only the 15w/30 ESP one, none of the other Mobil oils are VW approved.
Offline ub7rm
« Reply #8 on: 02 February 2010, 20:48 »
Sorry typo, should have said 5W/30 ESP ... will correct in my original post.  :embarassed:
2020 BMW 128ti
Offline Stitch
« Reply #9 on: 02 February 2010, 20:55 »
A quick Google serch suggests the Mobil 1 5w 30 is used by VW dealers. phew.
It'll be in for a service in a few weeks so will be interesting to see what they put in this time (I still have 4 litres of Mobil 1 left though so I hope they haven't changed it!).
