Author Topic: MKV GTI - which top-up oil?  (Read 4574 times)
Offline clint4one
Re: MKV GTI - which top-up oil?
« Reply #10 on: 02 February 2010, 21:52 »
My car is on long life services, but some one recommended  to get the oil changed every 8k miles rather than 20k. I use a 5w 40 oil which fits vw spec for normal services is this ok?
« Last Edit: 02 February 2010, 21:55 by clint4one »
2009 MKV R32
Offline Stitch
« Reply #11 on: 02 February 2010, 22:36 »
Had me worried there but thanks for the reassurance. Car is out of VW warranty now anway but I plan to keep the FVWSH so good to know I've been using good oil. I have used Mobil 1 in the Elise's and the Beamer I had - it'snot cheap but I think it's one of the better ones.
I'll check with VW but that can't be correct or someone needs to tell the Cardiff and Bridgend VW dealers then as the top up oil i've bought from them is the 5W 30 ESP Mobil 1 which they also filled my car with on the long life intervals (I find it odd that both independant dealers would get that wrong (they are now under the same name after Cardiff VW went under but at the time of my services they were indpendant of each other).
Mobil 1 didn't used to be VW approved but the ESP oil your stealer is using is fully approved by VW.  But only the 15w/30 ESP one, none of the other Mobil oils are VW approved.
Sorry typo, should have said 5W/30 ESP ... will correct in my original post.  :embarassed:
Offline Stitch
« Reply #12 on: 02 February 2010, 22:37 »
Chainging the oil more frequently is always a good thing but I'm not sure about the 5w 40 compared to 5w 30 sorry.
Offline tonym1
« Reply #13 on: 04 February 2010, 19:42 »
easy go to vw dealer he should ask the reg and know from there if youre car has been serviced properly by vw and then he will sell you the same oil that they have been putting in when serviced  thats what happens to me.
